Interchangable with LT1 & LS1?
Old Jan 15, 2006 | 07:27 PM
Roach02's Avatar
Question Interchangable with LT1 & LS1?
Okay i bought a used N.O.S. kit that for my 95'Z. THe guy I bought it off of was running it on his 96' V6 Camaro. Would this kit work on an LS1 also because a buddy wants to buy it off of me as i'm trying to sell it?
Old Jan 15, 2006 | 08:19 PM
383LQ4SS's Avatar
Re: Interchangable with LT1 & LS1?
Is this the 5176 kit?
You will defiantely be able to use what you have for a kit on the LS1...even if its a simple dry setup. If your setup is wet kit...that will work too. Just put the nozzle in the intake beloows in fron of the TB.
If you want to make a dry kit just put the nozzle in front of the MAF but not pointed directly at the MAF. A dry nozzle would be best for the dry setup obviosuly.
Old Jan 15, 2006 | 08:36 PM
Roach02's Avatar
well see i don't know what the kit number is as i bought it used. thanks for the help.
Old Jan 15, 2006 | 09:50 PM
Is it a wet or a dry kit?
Old Jan 16, 2006 | 09:04 AM
Roach02's Avatar
well it started as a dry kit but the previous owner bought everythign to make it a wet. So it has both.
rideordie
Nov 5, 2019 04:52 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
LewisW96
82
Feb 24, 2008 04:49 PM
