Reset the bead!! Dangerous!!!
Old Dec 29, 2005 | 12:08 AM
1FstFormulaV8's Avatar
So my friend and I were out about on a curvy country road. And I went around a curve and the passenger front tire rolled right off the bead. I was sighing and carrying on how I have to get the tire fixed and yada yada yada. While I was taking out the jack and spare. I find a can of starting fluid. I remember reading and seeing this little trick work, I gave it a shot. And I'll be damned if it didn't work like a charm. It put the tire right back on the bead no problem. I drove to the closest gas station and filled it with the correct amount of air. Drove home, no problem. Prolly about 7 miles home.
I know this is a VERY VERY dangerous thing to attempt. But it actually worked quite well!
Old Dec 29, 2005 | 09:15 AM
johnnyb's Avatar
Re: Reset the bead!! Dangerous!!!
did your rim get messed up when it happened? ive reset the bead on a couple of tires- i just filled them up with air and they popped right on.
Old Dec 29, 2005 | 10:23 AM
For reference, what size tire are you running, on what size wheel?
Old Dec 30, 2005 | 03:22 AM
Stocker
235/35/16"
The lip of the wheel isn't a pretty sight.
Old Dec 30, 2005 | 10:19 AM
johnnyb's Avatar
i thought that the stock wheels called for 245 or 255? if your tire is too narrow, it will be coming off again
Old Dec 30, 2005 | 11:19 AM
4U 2 NV's Avatar
they have been using this method for years...in my opinion it can be sometimes less dangerous doing it this way because you can stand back and light the fluid from a distrance
Old Dec 30, 2005 | 12:11 PM
235/55-16 is a stock tire size. Base V8's came with 235/55-16 all-season tires. If you got the Z-rated tire option, you got 245/50-16's. A 255 was never standard. Most manufacturers recommend a wneel width of 6.5-8.5" for the 235/55-16.
Old Jan 4, 2006 | 12:58 AM
Dave '97 Z28 M6's Avatar
Here's a vid of the lighter fluid trick:
http://videos.camaroz28.com/Player.a...8667DE6BD4&p=0
Old Jan 4, 2006 | 08:40 PM
Resilient94LT1's Avatar
That's bad ***!
Old Jan 4, 2006 | 10:26 PM
RICEFEDZ28's Avatar
Alot of off roading guys always carry a can of starting fluid it works wonders.
Old Jan 6, 2006 | 09:51 PM
94camaro3.4's Avatar
learn something everyday
Old Jan 6, 2006 | 10:46 PM
oneslowz28's Avatar
it safer alot of times even when mounting new tires. some of the larger 20" and above wheels are hard to seat the bead. i have put 100-150 psi in some and when the bead does set it sounds like a shotgun. this is also true for verry low profile tires too. if i have a tire that wont seat i always use the starting fluid/eather trick. it works great on those pesky lawn mower tires and atv tires too.
Old Jan 7, 2006 | 04:05 PM
slayer6x6's Avatar
Thats pretty wild!!
Old Jan 7, 2006 | 08:57 PM
Zack's Avatar
ive never had trouble with 20's and up
just takes a lil skill
surreybrad
Jul 29, 2015 02:55 PM
BigED
Jun 23, 2015 07:19 PM
Allen66
Nov 15, 2002 11:00 AM
camarosource
Jul 14, 2002 01:14 PM
MikeLS
May 17, 2002 06:41 PM
