Question about 1LE susp.
Old Dec 27, 2005 | 05:07 PM
Camm95Z28's Avatar
I am considering a 1LE sway bar and panhard rod bar for my 95 Z28. A friend of mine has said I would have to be careful cause that stiffer bar would make my Z ride very rough. I kinda belive him due to articles I have read back when the Camaro SS re-dubted with the same setup. Is my friend right about the stiff ride? Anyone have the same setup and experience? Thanks for reading and posting.
Old Dec 27, 2005 | 05:38 PM
MyShibbyZ28's Avatar
Re: Question about 1LE susp.
Does your friend have a 1LE panhard rod or sway bar?
Panhard rods do not make a ride stiffer (actually I think 1LE PHR's are the same as FE2 normal suspension PHR's), nor does a sway bar. They make the ride more "rigid". By that I mean PHR and sway bars make the car more stable. Both of those suspension parts have to do with cornering, not stiffness. They will keep the car from rolling and having the backend shift away from the axle.
PHR = keeps axle and body of car aligned together.
sway bar = prevents body roll.
Obviously the stiffer and better both these are, the better the cornering will be. Then of course there is always the point of getting oversteer/understeer.
1LE sway bar is bigger than FE2 so the upgrade is worth it, for PHR, I think they are the same size so it isn't worth it. I could be wrong though.
Old Dec 27, 2005 | 06:35 PM
Steve0's Avatar
Your ride wont get any worse. Go ahead and get the bar. THe panhard bar is the same as the stock unit with better bushings I believe. I would skip that one and save my money towards a tubular adjustable piece.
Old Dec 28, 2005 | 11:22 AM
Z28barnett's Avatar
The early SS had the 1LE front springs 360 vrs 290, that will make the ride stiffer.
I don't think the 32mm sway bar would cause a problem should be a nice upgrade. $29.00 on ebay from gryhead.com
I would leave the panhard alone unless it is failing.
Z28
Old Dec 30, 2005 | 07:45 PM
Camm95Z28's Avatar
Thanks for the posts. I have learned a little bit. I was curious though about the ride, cause the SS I alwasy heard was so harsh, yet the WS6 was very stable , and yet they had almost the same setup. Thanks again
Old Dec 30, 2005 | 07:52 PM
Shempy's Avatar
i'd skip past the 1LE and go straight for a 35mm bar. As said, it's the springs and and sometimes improperly adjusted shocks that will harshen it. The 1le panhard isn't worth the trouble of swapping.
gto4u2
Mar 14, 2015 06:05 AM
Jason Short
Jan 19, 2015 06:34 PM
Compstall
Sep 9, 2002 02:16 PM
CARGASM
Sep 4, 2002 11:17 AM
MissedShift
9
Jul 17, 2002 10:31 PM
