ECM Codes decode
Old Dec 21, 2005 | 07:12 PM
ringo234's Avatar
ECM Codes decode
OK I figured out how to jump the connector. It 12,12,12 then 36,36,36, and finally 45,45,45 then began to repeat. I looked up the codes in a Haynes manual.
12 = ???
36 = MAF grounding problem
45 = replace O2 sensor - exhaust too rich.
I couldn't find a code for 12. Any Help would be appreciated.
Old Dec 21, 2005 | 07:31 PM
Wacky Tower's Avatar
Re: ECM Codes decode
code 12 is basically letting you know that the ecm is functioning. If you had no other codes it would only flash 12
Old Dec 21, 2005 | 07:44 PM
ringo234's Avatar
thanks
Old Dec 21, 2005 | 08:42 PM
Pneumatic_Tire's Avatar
Code 12 is basically just a code saying there is no distributor signal. Normal code that all flash first.
Old Dec 22, 2005 | 05:44 PM
nj85z28's Avatar
code 12 actually means Diagnostic Mode
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
H-street
Aug 21, 2002 05:41 PM
babyIroc87
Aug 8, 2002 04:07 PM
91Bird305
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
