Camshaft Question
Old Dec 20, 2005 | 11:55 PM
thesoundandthefury's Avatar
Camshaft Question
Okay, let's say you've hit the magic dynamic compression wall of 9:1, and you still have more room in the heads to make more power, but you need to bleed off some pressure to avoid detonation. If keeping VE as high as possible is the priority, which of these variables would you play with in the cam specs: grind in more overlap, or increase exhaust lobe duration? Why?
Old Dec 21, 2005 | 05:37 AM
rskrause's Avatar
Re: Camshaft Question
Longer duration.
Rich
Old Dec 21, 2005 | 06:31 AM
1racerdude's Avatar
Ya need a later IVC however ya get it.
Old Dec 21, 2005 | 08:21 AM
SStrokerAce's Avatar
Yep, and the wall might be lower than 9:1 in most setups as well.
Old Dec 21, 2005 | 12:56 PM
Can you elaborate on this please? Why would one engine have a lower DCR tolerance than another? What factors would need to be changed to raise that tolerance?
Old Dec 21, 2005 | 03:14 PM
marshall93z's Avatar
Cooling, tuning......tight quench maybe.
Old Dec 21, 2005 | 03:18 PM
jerminator96's Avatar
Higher octane
Old Dec 21, 2005 | 03:36 PM
93SS's Avatar
In reguards to cooling. What radiator is most people using with very high HP and 8-9:1 DCR's? This is in 93-97 F bodies with a LT engine type.
Old Dec 21, 2005 | 09:03 PM
The better the VE of the motor, atmospheric conditions, chamber shapes there is a lot that goes into it especially to be 100% detonation proof.
Bret
Old Dec 22, 2005 | 05:06 AM
LameRandomName's Avatar
Every time I see your dad's quote I find myself wondering if you are Robert Heinlein Jr.
Old Dec 22, 2005 | 07:48 AM
OldSStroker's Avatar
LOL!
"Most people can't think, most of the remainder won't think, the small fraction who do think mostly can't do it very well. The extremely tiny fraction who think regularly, accurately, creatively, and without self-delusion- in the long run, these are the only people who count." --- Robert Heinlein
Old Dec 22, 2005 | 11:11 AM
Looks like dad has a new quote for his sig just in time for Christmas.
Bret
MadMav
May 25, 2015 09:35 PM
Red_94Formula
Jan 22, 2015 12:17 AM
HCz28
Jan 11, 2015 11:17 AM
1775.Z28
Jan 11, 2015 10:51 AM
