Leaking master cylinder?
Old Oct 28, 2005 | 08:51 PM
Jeff95TA's Avatar
Is this considered a leaking master cylinder or is this what the shop manual refers to as "damp"?
https://home.comcast.net/~saccani/MasterCylinder.jpg
If it's leaking is it worth it to rebuild it or just buy a new one?
Old Oct 29, 2005 | 01:25 PM
OBE1 95Z28's Avatar
Re: Leaking master cylinder?
I wasn't able to find a rebuild kit; I picked up a rebuilt unit. Straight forward swap, just need to do a bench bleed first.
Old Oct 29, 2005 | 07:12 PM
Z28barnett's Avatar
Go to autozone and buy a new cap first.
The cap fingers get weak after a few years and allow fluid to seep out. Due to the angle it collects at the base of the MC.
If the MC is really leaking bad it comes through and you will get fluid on the carpet. Also you will get weak braking due to air in the lines.
Or clean everything and wrap a rag near the cap if it gets wet it is not coming out of the back of the cylinder.
Mine looked just like that, and it was the cap.
Z28
Old Oct 29, 2005 | 08:59 PM
Jeff95TA's Avatar
I'll definitely try that first.
I do have weak braking though, and I was hoping this was the problem.
Rod Bender
Nov 7, 2023 02:30 PM
Rod Bender
May 16, 2015 02:16 PM
R@mpage
Apr 20, 2015 10:02 AM
Ringmaster72
Mar 19, 2015 03:32 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
