what to expect
Old Oct 22, 2005 | 03:14 PM
1quickgt's Avatar
what to expect
just a estimate of hat to expect power wise for this h/c package. The heads are CNC’d ported lt-1's and have 2.00/1.56 Manley stainless steel valves, toped off with Crane’s springs and retainers kit 10308-1 with dual coil springs. The heads also have guide plates installed.
and the cam is a cc305 i just need to know what needs to be done in order to keep it runing smooth and reliable and will it pass air care...already toasted 1 tranny...dont need to blow a motor now as well
thanks in advance
Old Oct 23, 2005 | 11:17 AM
Zedzag's Avatar
Re: what to expect
Depends how well the heads were ported but I'd say 350rwhp + if your tune and port job are right on. With 114 LSA and a good tune she'll idle fine and smoke aircare. The bottom end can take the power easily and should pull to 6500 with the cam.
Now the tranny is another question.
Old Oct 23, 2005 | 01:11 PM
JD30thZ28's Avatar
Re: what to expect
Do you have any flow numbers on the heads???
Old Oct 23, 2005 | 03:20 PM
oldschool's Avatar
Re: what to expect
Thats a similar set-up to what I have...
My heads could probably use more attention but I am told they flow about 255cfm @ 600 lift. (I'm pretty sure thats what Mike told me)
With the 305 cam, full bolt-on's and only Matt's seat of the pants tuning, I made 336rwhp. I am sure it could get more hp with some tuning as I was at 11.25 air fuel ratio the whole time.
With my rev-limiter set too low for my 4.30 gears (hits the limiter atleast 100ft before the traps), I still managed 109mph in the 1/4 with a 3850lb car.
Finally, my car passed air scare with FLYING colours and I didn't even have to detune it. I did have two brand new cats though.
I hope that gives you an idea of what you are up against.
Andy
Old Oct 23, 2005 | 04:30 PM
sideways_Into_3rd's Avatar
Re: what to expect
I had the CC305 cam with untouched stock heads, shorty headers and single exhaust, and my tuning i made 334 rwhp and ran 110 mph on street tires .. so with some heads and decent installation and tuning you should make at least that and more. with an auto tranny, you should be well in the 12s .. CC305 is the best street cam you could put in your car IMO
Old Oct 23, 2005 | 05:02 PM
1quickgt's Avatar
Re: what to expect
thanks alot boys i'll be running johnnys old vig 2800 stall as well, your help is very apprecated as always
thanks again
Craig
Old Oct 24, 2005 | 06:07 AM
Wpns Grd Plutonium's Avatar
Re: what to expect
What's a trans am GT?
Old Oct 24, 2005 | 10:23 AM
talos's Avatar
Re: what to expect
wasn't it like the pontiac version of an F1 Camaro? just a title and few small mods?
2QUIK6
Sep 17, 2016 02:31 PM
drt
Sep 27, 2015 04:39 PM
WPHIG2
Aug 27, 2015 06:37 AM
nd4spd200
Aug 21, 2015 09:30 AM
13qtr
Jul 19, 2015 05:30 PM
