lt1 ram air converson part numbers needed
Old Oct 17, 2005 | 10:44 AM
sc1twntrbo's Avatar
i have the hood and air box. i just need to know were i can get the bellow peice (the peice between the maf and throttle body) and a maf wire extender, ive seen the extenders before but cant seem to find them again. i really dont wanna cut my wires.
thanks
Old Oct 17, 2005 | 10:50 AM
sc1twntrbo's Avatar
Re: lt1 ram air converson part numbers needed
oh and i also need to know the best place to get the grills for the hood
Old Oct 17, 2005 | 10:58 AM
97FormulaWS-6's Avatar
Best bet for the part from the MAF to TB is just a Fernco Pipe Coupler, 3" to 3" available at any Home Depot. Heat it in boiling water to soften it, then just slip it over both parts.
Old Oct 17, 2005 | 12:20 PM
I'll sell you my old "bellows"..... its been replaced with the Fernco ($5 with the two clamps).
http://cjcfo.fbody.com/members/injun.../DCP04252a.jpg
I'll also look to see if I still have the MAF sensor extension.... as you can see from the photo, I didn't need it.
There is also a molded hose that runs from the airbox to the AIR pump. Are you interested in that?
You will need a rubber insert where the MAF pushes into the airbox, if I recall correctly.
Old Oct 17, 2005 | 07:21 PM
TJ Chapman's Avatar
RKSport.com has grille inserts for the aftermarket SS hoods
Polished hood grille insert
Old Oct 17, 2005 | 11:16 PM
sc1twntrbo's Avatar
those are for a SS do they have them for a ws6 and in black not polished??
Old Oct 18, 2005 | 07:17 PM
TJ Chapman's Avatar
oh duh! 97 Trans Am withan SS hood, that would look REAL cool sorry
but LMperformance.com sells a Trans Am ram air hood that comes with grilles, so somewhere you must be able to buy just the grilles. . . maybe. . . you'd think
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
CobraEatr
Jul 22, 2002 09:49 AM
