Strange smell after 150mph run
Old Oct 15, 2005 | 06:22 PM
Grims's Avatar
I was racing a guy and held it to around 150mph, slowed down ...eveything was fine...but i was getting a real strange smell from the backseat area that I have never smelled before. It didn't smell anything like clutch and I have no idea what it might of been...any ideas?
Old Oct 15, 2005 | 07:04 PM
n2ceptor's Avatar
Re: Strange smell after 150mph run
Diff fluid/ tranny fluid hot?????
Old Oct 15, 2005 | 07:07 PM
dragster98's Avatar
im going with diff fluid it most likely phomed up like boiling milk
Old Oct 15, 2005 | 07:46 PM
MotorCityNova572's Avatar
maybe it could have beed the crap in your pants....or it could have beed the guys *** that you smoked.lol sorry i had to...
Old Oct 15, 2005 | 07:51 PM
95HellBird's Avatar
i had a strange smell in the back of my bird when i did that cept i held it for about 4 miles at 140ish, it was the diff fluid...so im pretty sure thats your problem
Old Oct 15, 2005 | 08:00 PM
Grims's Avatar
is it normal...or something I need to take care of, and if so what do i need todo?
Old Oct 15, 2005 | 08:12 PM
n2ceptor's Avatar
hOW LONG HAS IT BEEN SINCE YOUR LAST DIFF FLUID CHANGE???? Sorry caps.....
Old Oct 15, 2005 | 08:14 PM
Grims's Avatar
never that i know of, 140k miles on car.
Old Oct 16, 2005 | 07:48 PM
crasher88's Avatar
plz tell me your kidding. Replace it immidatly unless you want to have your rear end rebuilt any time soon. I change mine at the begining of every year along with some other yearly mantinace that I do. Simple to do in your drive way just crawl under your car, might have to jack the back end up enought for you to squeez under there. Undo the bolts that hold the cover on and take a screw driver and pry the covers off and let all the old fluid drain. While the old fluid is draining clean off the cover and prep both serfaces, clean off all the old gasket material and make sure its really clean. Take some silicon sealant apply it to the covers and put it back on the rear end and bolt it back down and snug up all the bolts nice and tight. Find the fill plug, should be on the side of the pumpkin just above the axle tubes, and take it off. Fill the rear end up until fluid start comming out of the fill tube and reinstall the plug. Clean up and your all done. Oh yeah and if you have a LSD don't forget to put in some LSD/friction modifyer in along with the rear end fluid.
Old Oct 18, 2005 | 09:40 PM
Grims's Avatar
oh, oops...
Old Aug 15, 2024 | 08:45 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs up Re: Strange smell after 150mph run
150 MPH?, You probably crapped in your pants (LOL)
Old Aug 15, 2024 | 10:59 AM
Grims's Avatar
20 years later, can confirm
jb4xx
Feb 2, 2015 10:00 PM
Iamherefornow
Jan 26, 2015 04:57 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
Sixer-Bird
10
Aug 25, 2002 01:12 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
