Somebodys got to have an answer for this.......
Old Oct 10, 2005 | 08:31 AM
stubbs's Avatar
OK I installed a 58mm TB on the Vette. The stock airtube was rotted out and leaking so I got one of those rubber ones from Ecklers I think it was, well anyway, that thing sucks, after awhile the glue dries out and it splits open. But the stock airtube is too small to fit around the 58mm TB. I would try to make a solid pipe with 2 short rubber hoese like on the CAI kits, but the Mass Air end is round and the TB end is oval, and I have neither the knowlede nor the equipment to figure out how to bend that. So what do you guys do? I can't be the only person running a 58mm TB. So what sollutions have you guys come up with? I am driving across the country in January and am trying to fix all the little problems before I go.
Old Oct 10, 2005 | 12:40 PM
Kiroc89's Avatar
Re: Somebodys got to have an answer for this.......
would the bellows from a MAF iroc/z28 work, I know it goes form oval to round for the maf sensor and is big enough for the tb as it has an adjustable hose clamp, just don't use the dual snorkel thing after the maf...it could work
Old Oct 10, 2005 | 02:22 PM
Z28SORR's Avatar
You have me confussed. The outer dimensions of my after market TB(Holley 54mm) were the same as stock, only the throttle plates were different. The reason for going to the "Ecklers" boot is because it's smooth. If you don't like it you shoudl be able to use a stock one.
Old Oct 10, 2005 | 07:41 PM
blown3rdgen's Avatar
heat it- it will stretch
matt
Old Oct 10, 2005 | 08:37 PM
90rocz's Avatar
Can you wrap a string around the TB and see what tubing has the same circumference, then you can squish the tubing in a vise and find a piece rubber hose that will fit over them both.
Old Oct 10, 2005 | 10:13 PM
stubbs's Avatar
A 52 mm throttle body has the same outer circumference as a stock 1 but the 58 mm throttle body has a larger outer circumference.
I guess I could heat and stretch a stock bellows, but it just seems to me like it must steal so much horsepower. I can't believe with all of the 58 mm throttle bodys out there that nobody makes an aftermarket bellows for this application?
I've never actually measured the diameter of the flange on the mass air flow meter and the throttle body, I always thought that the throttle body had a much bigger outer diameter, but I'll take a look at. Squishing a tube to fit may be a possibility. Thanks
Stubbs
Old Oct 11, 2005 | 12:37 PM
Z28SORR's Avatar
The TB is definitely larger than the MAF. You might try reinforcing the seam on the one from Ecklers. You could sew it, glue a thin piece of rubber over it, cover it with tape, etc.
Old Oct 11, 2005 | 12:39 PM
km9v's Avatar
2 words: duct tape
Old Oct 12, 2005 | 01:25 AM
iansane's Avatar
I think for the mild mods you have the horsepower loss is a moot point...
And I'd measure both TB's to see if they're actually different.
Old Oct 12, 2005 | 05:30 PM
90rocz's Avatar
Stubbs: I've never actually measured the diameter of the flange on the mass air flow meter and the throttle body, I always thought that the throttle body had a much bigger outer diameter, but I'll take a look at. Squishing a tube to fit may be a possibility. Thanks
I can't take credit, I saw this I believe in CHP a year or so ago. They had a piece of exhaust tubing, mandrel bent, I believe 3 inch or 3.5 inch, and it squished to the exact size needed.
Old Oct 13, 2005 | 01:46 AM
iansane's Avatar
I'd guess 3.5"
I tried 4" awhile back and it was too big. I bet 3.5" would be perfect. (and I've heard about this before)
Daluchman1974
Sep 11, 2015 06:12 AM
cmsmith
Aug 9, 2015 07:30 PM
michaelzilinski
Jul 31, 2015 08:41 AM
NewsBot
Jul 29, 2015 08:10 PM
Noct
Jul 14, 2015 01:18 AM
