Code 33
Old Oct 8, 2005 | 06:00 PM
nikeman211's Avatar
Code 33
I need to know what a code 33, MAP sensor signal voltage too high, means. The only time my car throws this code is when I put it in drive and hold the brakes. It is a 1995 Camaro z28.
Old Oct 9, 2005 | 11:08 PM
Re: Code 33
It means the MAP at idle (or with throttle position less than 4%) is above 68kPa for more than 5 seconds. With a stock cam, that would likely indicate a problem with the sensor, or excessive misfires, or extremely unstable/low idle speed. With an aftermarket cam, if its big enough, it could be normal. Do you have an mods..... like a cam?
Old Oct 14, 2005 | 07:59 PM
nikeman211's Avatar
Re: Code 33
yes i have a cam. the specs are lift intake .510, exhaust .540, and duration at .006
Old Oct 14, 2005 | 08:24 PM
shoebox's Avatar
Re: Code 33
If you don't have a reprogram for the cam to bring the idle up, you are probably going to get that code.
Old Oct 17, 2005 | 12:23 AM
nikeman211's Avatar
Re: Code 33
I have had this car for about a year now and I never got this code but I just changed a o2 sensor about a week before it started throwing this code.
Old Oct 17, 2005 | 10:33 AM
Re: Code 33
Its not the amount of lift that determines the intake manifold pressure, its the duration and overlap. What are the specs on duration and lobe separation angle?
You might also want to look at the harness connector for the MAP sensor. They dry out and crack, resulting in intermittent voltage problems.
Old Oct 17, 2005 | 10:35 PM
nikeman211's Avatar
Re: Code 33
Duration at .50 intake 229, exhaust 245, lobe lift intake .3400, exhaust .3610, and lobe separation 112.0
Old Oct 18, 2005 | 09:35 AM
Re: Code 33
With a 16deg split on the exhaust duration, you're way beyond my knowledge of expected vacuum at idle..... I don't think I've ever seen an LT1 cam with that much split.
What kind of MAP you see will depend very much on how good the tune is.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
