Maf options
Old Oct 25, 2002 | 09:16 PM
neil350's Avatar
Maf options
Ok, see we sit here preplexed on what to do, my buddy has an 86 Trans Am, put a ton of work in to it, its an LB9 so it has a MAF Tuned Port Injection system, we just did heads and cam, what computer tunning options are avail? I know one is to go for the SD 90-92 options, but wouldn't that mean a complete new wiring harness, computer and intake assembly? So we might as well rip off the entire TPI system and go find a 90-92 set up or what?
Old Oct 25, 2002 | 11:16 PM
aklim's Avatar
Going to speed density is a bigger pain than it is worth. Why are you going that route? What is wrong with the MAF setup? It is more adaptable and gives a more true air flow number than a SD system. You would have to change the Knock sensor because it is different in the 90-92 models.
I'd leave it alone and go talk to www.fasterproms.com and have them burn you a chip to take care of it. Even if you went to SD, you would still have the problem of the heads and cam which the computer cannot compensate for.
Double aught
Oct 2, 2015 11:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
