Manual Steering
Old Sep 14, 2005 | 03:49 AM
EvlViln's Avatar
Question Manual Steering
Why is it that the manual steering rack made by mad man racing is like $700 buck and a pinto rack from summit is like $300? Would a pinto rack fit?
Are there any other options for manual rack & pinion?
Thanks!
D$
Old Sep 14, 2005 | 07:22 PM
crazypurgatory's Avatar
Lightbulb Re: Manual Steering
Thanks!
D$
It would help to know what year camaro.
I'm guessing a 1993-1997?
As far as I know the pinto rack won't fit.
What you can do but it will cast you about the same as the mad man rack is to buy a BMR K-member for a pinto rack.
Then buy the Pinto rack or buy a reman from an autoparts store.
If you get the mad man rack you have to drill out the spindles to fit the tie rod ends on.
I would think you would not have to do that with the pinto rack.
Chris G.
Old Sep 15, 2005 | 10:25 PM
EvlViln's Avatar
Re: Manual Steering
Sorry, yeah, 94 Firebird....
I already have a BMR K-member.
Is the Madman the only 93-97 Manual R&P out there?
Thanks...
Old Sep 15, 2005 | 10:53 PM
96speed's Avatar
Re: Manual Steering
Because he welds mounts to the rack to allow use in a stock Fbody mounting style. The standard rack needs to use standard pinto mounts. I think his also includes steering shaft linkage, which is another ~100 bucks for good joints, and ofcourse the bumpsteer kit. Overall, I don't think its a steal to buy a standard setup, but it is a bit cheaper.
www.smithperformance.com
www.ajeracing.com
Ryan
Old Sep 15, 2005 | 11:21 PM
jeepramz
Guest
Posts: n/a
Re: Manual Steering
Why can't you just use the power steering rack without the pump?
Old Sep 15, 2005 | 11:27 PM
96speed's Avatar
Re: Manual Steering
Because the manual steering setups use a higher/slower ratio. Makes its easier to turn than a stock setup. A manual rack is much easier to turn than a stock rack with no power steering. Also, it defeats the purpose of saving weight.
Ryan
Old Sep 15, 2005 | 11:37 PM
jeepramz
Guest
Posts: n/a
Re: Manual Steering
It is only 6 lbs lighter. Could you use one of these to make it easier to turn?
http://static.summitracing.com/globa...re-522b2_w.jpg
Old Sep 16, 2005 | 12:07 AM
Thanks...
Well I think your cheapest way would be to call BMR up and see if they will sell you the mounting tabs for the pinto R&P.
Get a re man rack and your done with it.
I re man rack at auto zone is like 160 bucks.
With a life time warranty too.
Have somebody weld the mounting tabs on and your done.
Probably for less than half of the Mad Man rack.
Chris G.
Old Sep 17, 2005 | 11:23 PM
96speed's Avatar
Re: Manual Steering
Keep in mind that using stock mounts keeps your options open. I thought I wanted a drag car but decided that was the wrong direction. I had already bought a BMR pinto mount Kmember after I decided that a manual rack was too much for my tastes. Just my .02 .
Ryan
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
67chevy
Parts Wanted
Jul 20, 2015 02:27 PM
240ssLs3
Jul 13, 2015 05:06 PM
ducttape1975
Jul 10, 2015 06:29 PM
colts0455
Jul 7, 2015 07:19 PM
