Jumping the AC compressor?
Old Aug 27, 2005 | 04:23 PM
crAzy95z28's Avatar
on the relay what numbers do i put together to jump the AC compressor?
also all i have to do is touch them together and then turn the ac on and the compressor should start working right?
and i also can use a caot hanger wire or just a wire correct?
Randy
Old Aug 28, 2005 | 08:49 AM
Dave89IROC's Avatar
Re: Jumping the AC compressor?
jump pins 87 and 30 at the relay plug, a piece of wire will work ok, if for some reason it starts glowing, pull it out with pliers(will be hot)
Old Aug 29, 2005 | 07:07 AM
94_Z28_guy's Avatar
Paperclip works well.
Old Aug 29, 2005 | 08:01 AM
Kataklysm's Avatar
Why are you going to do this? You can damage wiring, its just letting all the voltage it can go through it. Circuits are not set up to hold as much voltage as you can put to them.
Old Aug 29, 2005 | 05:20 PM
crAzy95z28's Avatar
well then why wont it come out without jumping the wires?
ive used new relays they still dont work!!
Old Aug 29, 2005 | 05:55 PM
Dave89IROC's Avatar
if you are low on freon, it stops the relay from operating the compressor, as operating on a low charge will hurt the compressor
Old Aug 29, 2005 | 08:37 PM
ArcticHuggerZ's Avatar
If the PCM sees that the compressor cycles on and off too much it can tell that it is low on freon and shuts the system down. Also if the signal wire going to the relay is bad the relay won't ever kit on , no matter how many good ones you put in there. The pins you are jumping is a battery voltage(power wire) and the power wire going to the compressor. There is a reason that no signal is going to the relay and you need to get that checked out. You don't want to cook that compressor clutch ..... money.
Old Aug 29, 2005 | 09:42 PM
Kataklysm's Avatar
Please, it's not freon anymore. Freon was R12, we use R134A now. Yes I am **** and people won't change but it's like a pet peeve.
PopoFormula
Oct 12, 2015 04:19 PM
War Engine
Sep 18, 2015 07:28 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
tdigger9899
Sep 7, 2015 10:56 AM
