tubing size
Old Aug 20, 2005 | 10:11 PM
akafred's Avatar
tubing size
what size tubing exhaust size tube would i need for 2 60-1 turbos on a 383. how much bigger should the down pipe be than the pipe from the header to turbos? would 2 1/2 from the header to the turbo be enough and then dual 2 1/2" exhaust or would dual 3" downpipes be reccomended ? the problem is i dont think i could fit dual 3" exhaust in the tunnel? mabey i can go to 2" after the cats
let me know what you think
thanks
Old Aug 20, 2005 | 10:19 PM
97WS6SCharged's Avatar
Re: tubing size
If you're concerned with space, you may want to stick with a large single instead of the twins. On my S10, I have 3" pipe running off of each PT61. You really don't want to neck the pipe down if it can be helped.
Old Aug 27, 2005 | 06:59 PM
akafred's Avatar
Re: tubing size
so what your saying i would need 3 inch tube going to and from each turbo?
or should i run 2 1/2" to each turbo than 3" down pipe from each turbo to possibly a single 4" mufflex or simalar or dual 3" exhaust
Old Aug 27, 2005 | 08:33 PM
SMOKNZ's Avatar
Re: tubing size
Thats exactly what I did.
Old Aug 28, 2005 | 11:42 AM
akafred's Avatar
Re: tubing size
what did you do 3" to and from
or 2 1/2 to and 3" from???
Old Aug 28, 2005 | 02:09 PM
SMOKNZ's Avatar
Re: tubing size
I used a 3" collector, reduced it down to 2.5" then into the turbo's. Out of the turbo exhaust I used 3" to a y pipe and used a 4" mufflex system. On the compressor side I used 2.5 inch pipes to the intercooler, then a 3" to the throttle body. Hope it clears up some misconceptions.
Bill
Old Aug 28, 2005 | 03:44 PM
akafred's Avatar
Re: tubing size
that is what i thought would be best as it might have a higer velocity going into the turbo with the 2 1/2 thanks
Old Aug 28, 2005 | 03:53 PM
akafred's Avatar
Re: tubing size
do you have any pics of your setup??
Old Aug 28, 2005 | 05:59 PM
SMOKNZ's Avatar
Re: tubing size
Yeah, I do, but my web page is down right now, I gotta get around to moving it to a different server... I can email you if ya want, let me know
Bill
Old Aug 29, 2005 | 06:34 PM
akafred's Avatar
Re: tubing size
What all did you loose eg air p/s ect to make this work?
Old Aug 29, 2005 | 08:29 PM
SMOKNZ's Avatar
Re: tubing size
Just air. Still have all the stock accessories. I used a 1LE pully and cut one of the ends off of it and turned it around backwards. I was able to sneek a 3" downpipe past that stuff!!
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
jmadoll
May 27, 2015 07:13 PM
