95 Firebird flip up head light question
Old May 23, 2005 | 04:55 PM
ABA383's Avatar
When I turn off my headlights they go down fine, but the driver's side makes a horrible grinding noise for about 10 seconds which is coming from the motor with the rubber boot over it to manually flip up/down the lights. I'm assuming that this is the headlight motor with stripped gears...There is a number on it that looks like a part # 16521997LH, but I can't find it at GMpartsdirect.com. Anyone have the number to this "motor" or have a driver's side laying around they don't need and would like to sell? Thanks..
--Alan
Old May 23, 2005 | 10:16 PM
Re: 95 Firebird flip up head light question
Might be able to fix it simply by "flipping" the nylon gear, or buying a new metal gear. Check out the info in this thread from a couple days ago:
http://web.camaross.com/forums/showthread.php?t=369025
Old May 24, 2005 | 02:59 PM
ABA383's Avatar
Thanks Fred...Just went to dealer...$179 with a decent discount...I'll try the FREE fix first...thanks again..
--Alan
Old May 24, 2005 | 05:17 PM
ABA383's Avatar
Well, as luck would have it the free mod didn't work...Now it makes noise in the up position Oh well, guess it's time for either the gear replacement or a new unit for $179...I'm leaning towards a new one only because with my luck I'll bust the casing trying to put in the new gear, plus the light was hesitating just a little before it moved...Oh well, thanks Fred and Brent anyway...
--Alan
Old May 24, 2005 | 06:20 PM
moparman's Avatar
Before you pay $179 for a motor, contact Dal or Jason Cromer and see it the price isn't a lot better.
Old May 24, 2005 | 07:13 PM
ABA383's Avatar
Thanks, I'll check with them...I have a local guy who matches/beats GMpartsdirect prices...once you add the s&h GMpartsdirect charges...the $179 includes tax...
--Alan
Old May 24, 2005 | 08:22 PM
Brent94Z's Avatar
Super Moderator
You most likely won't need to spend the money on a new motor. Try the free fix and at the worst you'll need to remove the nylon gear and rotate it 90 degrees for the free fix to work. Good luck!
Old May 25, 2005 | 06:48 AM
1quickTA's Avatar
The free fix should work at least once, sometimes twice. When that stops working because the whole gear is worn out, you can get a replacement metal gear here and this should fix your problem for good:
http://www.bfranker.badz28.com/headlightfix/index.htm
The guy who runs this site is awesome and should be helpful. Good Luck.
Old May 25, 2005 | 08:27 AM
Brent94Z's Avatar
Super Moderator
Thanks!
When you do the 180 trick and the gear strips on the way up instead of down, for example, what that means is that enough teeth are worn in that one area that it now affects the operation in the other direction. This can still be fixed for free by paying attention to the orientation of the gear and shaft and rotating the gear 90 degrees instead of 180. This puts the bad teeth completely out of the picture on the side that isn't used (just have to rotate it the correct direction!). However, easiest and longest lasting fix will be the brass gear. Even with a completely new assembly, it will likely fail again. I've talked to people who have had 3 new setups fail on the same side. On the 4th failure they found my page because the car was out of warranty and they didn't want to spend $400 on one light Several I've talked to have had several failures like this with all new units... the design is very poor.
Old May 25, 2005 | 08:40 AM
RocCityZman's Avatar
--Alan
And if the free fix doesn't work and you don't want to put in Brent's gear check out e-bay. There's lots of headlight motors for sale on there (new and used). I've been looking for whole assemblys for my Formula and have seen alot of motors up there.
Old May 25, 2005 | 02:13 PM
ABA383's Avatar
Thanks all...I just found a deal on a new motor for $90 from a friend...I'll see how long it lasts then go with the brass gear...Thanks all again...
--Alan
LT14LIFE
Feb 9, 2015 09:35 PM
cmdeshon
Dec 27, 2014 10:06 AM
Injuneer
Dec 15, 2014 09:36 AM
CaRParts102
Dec 6, 2014 08:45 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
