will they fit?
Old May 15, 2005 | 06:59 PM
the_tight's Avatar
will they fit?
wanted to know if 295 45 18 will fit on a 9.5 wheel ?
Old May 15, 2005 | 07:24 PM
onthemat's Avatar
Re: will they fit?
I put 295/35/18 on a 9.5 inch wheel. Looks fine and no sidewll flex.
Old May 16, 2005 | 07:17 AM
teke184's Avatar
Re: will they fit?
45 series on a 18" rim is a BIG tire
that tire has a diameter of over 28"....2.75" bigger than a standard f-body tire
Old May 16, 2005 | 07:45 AM
Re: will they fit?
Yes.... a 295/45-18 will fit on a 9.5" wide wheel, per the manufacturer's recommendations. The next question is what year car are you trying to put them on? They are 28.4" diameter, and for example, will not fit in the fender openings of a 4th Gen without major surgery. I run 28.1" slicks, and had to relocate the rear axle, and cut about 1.5" off the rear bumper cover.
Finally, questions about "wheels and tires" should be posted on (surprise ) the "Wheels and Tires" forum..... moving thread there.
Old May 16, 2005 | 10:10 AM
Zack's Avatar
Re: will they fit?
295/45/18? saw a pair on a mustang at work...looked so stupid
Old May 16, 2005 | 09:30 PM
the_tight's Avatar
Re: will they fit?
ok well let me ask this what size is the best for a 18x9.5 wheels in the rear of a 4th gen z28???
Old May 16, 2005 | 11:07 PM
Re: will they fit?
275/35-18 or 285/35-18
Old May 19, 2005 | 08:10 PM
zmokum's Avatar
Re: will they fit?
what about a 285/35/18 on the front?....anyone know?
Old May 19, 2005 | 08:28 PM
97SLPcamaroSS's Avatar
Re: will they fit?
im running 275/35ZR18 with no rub with a 1.5" drop i run that size all the way aruond
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Jan 23, 2015 01:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
