Bought a tranny mount from AutoZone... got questions...
Old May 6, 2005 | 05:11 PM
Need4Camaro's Avatar
The $25.99 one from Energy Suspension, Polyurthane for GM RWD cars and 2WD cars...
If you need a part number then it is 3.1108G
I'm also running a V6 if it makes any difference...
Will this work?
Old May 7, 2005 | 04:24 PM
MustangEater82's Avatar
Re: Bought a tranny mount from AutoZone... got questions...
Yes and no...
Any poly mounts for v6 f-bodies you need to modify your crossmember. There are 2 bolts that go into the tranny and a single bolt connects the crossmember to the mount.
you need to extend the hole on the mount I have heard a 1/4 in, I had to do mine like 1/2 in. Some use a drill and just grind it down I used a dremel and cutoff wheel tooke me like 30 minutes total to do everything. I have the same one from autozone as you.
Old May 9, 2005 | 10:37 AM
Okay, thanks in advanced...
mattszm6
Dec 14, 2014 07:09 AM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
