Started Tuning :)
Old May 4, 2005 | 10:01 PM
Deenasty's Avatar
Started Tuning :)
I started my tuning experience. I have all the software possible, lt1 edit, datamaster, freescan, and I have a wideband in the car. Mods in the sig. I have chosen to go with a open loop tune only, do to the size of the camshaft. I first set the injector offset for my SVO 42's. Then went into the OPEN LOOP AFR vs. LOAD vs. COOLANT TEMP, and got the car to idle inbetween 14.7-15.1, with about 30° of timing. Tomorrow I am gonna go out and do some part throttle tuning. What should part throttle AF be roughly? High 13's? Now should it be mid to high 13's no matter the kpa, as long as I am on the throttle? Thanks guys!
Old May 20, 2005 | 07:42 PM
MaxLean's Avatar
Re: Started Tuning :)
How did you specifically set the idle fuel mix via the open loop afr/coolant/load tables without affecting cruise fuel ratios at the same map value?
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
97SSdude
Dec 31, 2014 07:43 PM
Brady
Jul 29, 2002 10:30 PM
