Did Interior with LED's...Uh Can I go Brighter?
Old Apr 3, 2005 | 11:54 PM
Need4Camaro's Avatar
They're red but the A/C and Shifter plate is PRETTY dim you can BARELY tell they're lit even at night... Any bright RED LED's out there that are small like the 74 Bulb size?
Old Apr 4, 2005 | 06:34 AM
97FormulaWS-6's Avatar
Re: Did Interior with LED's...Uh Can I go Brighter?
Just look for any high-brightness T-5 LEDs, they are directional, so overall they maybe still dim.
Old Apr 4, 2005 | 12:38 PM
What happens if I use a wide angle LED?
Old Apr 4, 2005 | 06:17 PM
You just loose some intensity, the same amount of light, you just spread it out more.
Old Apr 4, 2005 | 06:24 PM
I see so would those be better?
Old Apr 4, 2005 | 06:48 PM
Honest, answer, I don't know; something I'd say you'll have to experiment with.
Old Apr 4, 2005 | 07:43 PM
WS6Extreme's Avatar
I have some Red 20,000 mcd LED's with a 4 degree viewing angle can can be modified to provde you with the light you should need. I was using them in my Cargo Light and Map Ligth LED conversions. If you want bright these can cause eye damage if you look directly into them..
I have red 30,000 mcd 9 degree viewing angle LED's on the way.
Old Apr 4, 2005 | 07:46 PM
Whoa where'd you get those?
Old Apr 5, 2005 | 06:26 AM
The 4* and 9* is great for spot lighting, but for area lighting it sux. I've got some LEDs here at work that will blow those away, but they are SMT (surface mount) and actually require a heatsink to function properly; but when you are talking 150 cd with a 60* beam spread... that's a lot of light.
Old Apr 5, 2005 | 08:43 AM
WS6Extreme's Avatar
Care to share who makes them and the part numbers?
The LED's I mentioned would work fine if you modified the housing a little to better light dispersion. Yea you give up some of the mcd, BUT it will illuminate a larger area without a heatsink.
Old Apr 5, 2005 | 04:36 PM
meissen's Avatar
Oznium.com has red leds with an 8000 30-some degree viewing angle, at 34 cents each, it's a pretty decent buy...
Old Apr 5, 2005 | 08:59 PM
www.lumileds.com for the product, www.futureelectronics.com for the sole distributor.
Old Apr 9, 2005 | 10:25 AM
Do those come with resistors so I can wire it directly to my car? Will I have to drill a larger hole for the shifter plate?
nosliw
Mar 9, 2016 04:56 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
alphaauto
Jul 26, 2015 04:40 PM
