best intake for this BBC
Old Mar 22, 2005 | 05:32 PM
Rice Killer87's Avatar
I have a brand new 468 on the way with oval port heads and a Comp Cams 292H-10 cam installed already (.550/.550 292/292 duration 110 LSA).
It's coming minus an intake and I was wondering what you guys think would work best. It is going into the 79 in my sig. and is going to be alot more of a race car than a street car.
Dyno2000 shows that combo making 599HP @ 6500 and 563 Ft/Lbs at 5000 RPM's with a single plane intake.
Hood clearance isnt really an issue b/c its got a 4" glass cowl hood on it.
Old Mar 22, 2005 | 07:26 PM
rskrause's Avatar
Re: best intake for this BBC
I wonder what the logic for the hyraulic cam vs. a solid lifter on a car more race than street. Ditto the oval port heads. But you should be looking at a max of ~6,500rpm (assuming the heads match the cam). There are certainly a lot of BBC intakes out there. But the Vic Jr. 454 would be a good choice among others.
Rich
Old Mar 22, 2005 | 07:54 PM
SStrokerAce's Avatar
Yeah there are only a couple of single plane Oval Port intakes.
Bret
Old Mar 22, 2005 | 09:11 PM
Stephen 87 IROC's Avatar
Since it's going to be more of a race car than a street car, I also vote for the Victor Jr. It's a very good single plane manifold. For a street car with some track time, a good dual plane like the RPM Air Gap should be used. The Performer and Performer RPM are nice but are more designed for a daily driver.
I think you're going to need to move some numbers around with DD2000. The HP is way too high for that combination.
Old Mar 23, 2005 | 01:53 PM
I was thinking Victor Jr. also,but I just wanted to see if anyone had used a different intake than that w/ good results.
about the heads/hydraulic cam...this 79 is mine and im gonna try to drag race it alot and i needed a motor to start out w/ to get used to the car,and practice b/c my dad wouldnt let me build a 600 HP motor to start out with. I know the oval port heads arent that great but the motor is brand new and already assembled w/ these parts on it so im just gonna go from there.
Thanks for the replys
Old Mar 26, 2005 | 10:34 PM
LameRandomName's Avatar
Have you considered one of the "street" type of tunnel rams?
They're building them a lot smarter these days, with tighter runners for higher velocity and I have seen a number of surprising dyno comparisons.
Edelbrock & Weiand both make 'em for the Oval Port heads.
Old Mar 26, 2005 | 11:24 PM
Nothing wrong with a good set of oval ports once some porting is done and some 2.19/1.88 valves are installed. My best results so far are with oval port heads. I destroyed a couple of 781 castings before buying some Merlins.
This year the engine has gone big. Big roller cam and rectangular port aluminum heads with big valves.
MadMav
Jun 15, 2015 09:51 PM
ChrisFrez
Mar 22, 2015 09:12 AM
1LEThumper
Jul 14, 2003 12:45 PM
Timberwolf
Oct 10, 2002 05:25 PM
80_OLDS454
Jul 20, 2002 12:03 AM
