clearance between hub and snout (ati superdamper)
Old Mar 15, 2005 | 11:06 PM
Highlander's Avatar
Well.. i still have yet to install my front damper.. i called ATI and they told me the correct clearance is "ten thousands" then he says .001. Which is it?
I would like to know with the instructions, what is the clearance for a press fit?
Thanks
Old Mar 16, 2005 | 11:25 AM
Lonnie Pavtis's Avatar
Re: clearance between hub and snout (ati superdamper)
I do not have a direction sheet presently, but I believe the following to be correct.
It is .001 press fit, not clearance for steel dampers.
Old Mar 16, 2005 | 11:40 AM
Highlander's Avatar
My Snout measures 1.247" (callies racemaster) and the ati bb hub measures 1.242"
Can i just heat up the hub and install it and let it cool?
Old Mar 16, 2005 | 02:52 PM
chevyguy3's Avatar
take the time to hone the hub to the correct fit. despite it seeming too tight to me, i forced an ATI superdamper onto the callies racemaster crank on my last engine because when i asked about it, thats what the guy who machined my shortblock said he always does. when it came time to try to get it off, all i managed to do was break 3 different hub removers and several grade 8 bolts trying to pull it back off and had no luck
Old Mar 16, 2005 | 03:11 PM
atljar's Avatar
Off topic...
On the ATI superdampre there are either 5 or 6 torx bits on the front of it. One hole is marked "alignment hole" or something to that effect. Isnt that suppossed to have a torx screw in it too? I dont remember when mine went together, but now there isnt anything in there.
Old Mar 16, 2005 | 03:12 PM
chevyguy3's Avatar
it should have 3 flat face bolts, and 6 countersunk bolts in it
Old Mar 16, 2005 | 04:24 PM
Highlander's Avatar
I talked to callies and they told me i should have around .003 clearance.... its a bit odd that you have that much clearance as you have that with pistons and they are not supposed to be pressed fit.. I will try and hone it to the 1.249" if at all possible which i am not sure if it could be done or not.... Lets hope and see.
Old Mar 16, 2005 | 05:35 PM
atljar's Avatar
Its one of the countersunk ones. Guess I will call ATI and get a new one, and install with a little locktite this time
Old Mar 16, 2005 | 07:45 PM
Highlander..... re-read my first post.
The confirmed press fit should be .0009" to .0012".
If you hone to 1.249, you will have .002 clearance & a junk hub. It should be 1.246" to have a .001" press fit on your 1.247 crank.
Old Mar 16, 2005 | 08:21 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
be careful with the loctite, i can't get those bolts off now! doh!!! lol!!!
Old Mar 17, 2005 | 01:10 AM
Highlander's Avatar
THANKS man.... i thought he meant the other way around.. THANK YOU!!! i knew something was not right....... having .002 overbore is like the pistons... they are not press fit.. thanks thanks thanks... getting that done.
Old Mar 17, 2005 | 10:40 AM
Sounds like what he said (or should have said) is you need a 10/10-thousandths (0.0010) interference fit.
AviatorDave
Dec 19, 2016 06:35 PM
Z Power
Sep 19, 2015 11:19 PM
karpetcm
Sep 15, 2015 11:07 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
Boss002
Jul 24, 2015 10:47 AM
