YSi owners
Old Feb 25, 2005 | 06:35 PM
GPZ406's Avatar
YSi owners
What size discharge tubing are you using? Car goes in the shop tomorrow for FMIC install.Vortech says 3" will be fine,just curious about your setups. Thanks!
Old Feb 26, 2005 | 05:50 PM
BLOWNBIRD's Avatar
Post Re: YSi owners
Well i run 4" on mine, but mines bigger!
Old Feb 26, 2005 | 07:52 PM
Blown406bird's Avatar
Re: YSi owners
3" is fine for us guys running "little" blowers
Old Mar 4, 2005 | 03:46 PM
383ysi's Avatar
Re: YSi owners
go for 3.5''
Old Mar 4, 2005 | 04:35 PM
z28draco's Avatar
Re: YSi owners
3 inch is the size of the outlet and a little smaller id on the ysi so 3 inch piping will be fine...i recommend aluminum with .065" thinkness, it is light, and can be polished out real nice
Old Mar 4, 2005 | 09:23 PM
Lonnie Pavtis's Avatar
Re: YSi owners
I've seen some "rule of thumb" info stating that 3" is good for 1000HP. Above that step up to the 3.5" The velocity & pressure is at its highest leaving the blower so this outlet size is less important than the rest of the tubing. Larger will not hurt if you want to take the extra effort to make it fit.
Old Mar 4, 2005 | 09:33 PM
64duece's Avatar
Re: YSi owners
We've made 1000+hp w/ a 3" discharge to the EV hat on a blow-through 406 SBC.
Old Mar 6, 2005 | 07:07 AM
GPZ406's Avatar
Re: YSi owners
Appreciate the replies.I`ll be using 3" .065 aluminum for discharge tubing and 4" into 5" for the blower`s inlet,routing it up to a filter over the dist. under the cowl of my hood.
I`ll be using 83# injectors,anyone know the limits of mini-ram fuel rails as delivered from TPIS?
Cooler is mounted,I`ll post some pics soon.
Old Nov 5, 2005 | 01:16 PM
Pro Stock John's Avatar
Re: YSi owners
The blower intlet is 4.00.
I run 3.00 piping throughout my setup, have made anywhere from 680-754rwhp this year with my stuff.
Formula Steve
Sep 19, 2023 08:31 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
cmsmith
Sep 14, 2015 09:09 PM
