torque converter question?
Old Jan 31, 2005 | 06:09 PM
slowZ's Avatar
Question torque converter question?
is there any way to tell what stall t/c is in my car? just curious because i've been having problems with it not shifting properly when i mash on the gas.
Old Jan 31, 2005 | 06:20 PM
ChevyTuffD.A.'s Avatar
Re: torque converter question?
U can get a general idea of what the stall speed of your converter is by holding the brake and giving it gas until the tires spin and whatever RPM they spin at is a close guess. This isnt the best or most accurate way to do it but itll work somewhat. Are u just trying to figure out if u have an aftermarket converter or what???
Old Jan 31, 2005 | 06:28 PM
slowZ's Avatar
yeah i think the original owner changed it and either didn't tune it, or done a poor job tuning it.
Old Jan 31, 2005 | 06:48 PM
well if its a reletivly higher stall then u could do the brake test and it will tell u, if its a stock stall then the tires should brake loose somewhere around 1600 rpm when holding the brake. I have heard about the OBD1 shifting issue with a higher stall, so check it out and let us know.
Old Jan 31, 2005 | 07:03 PM
94zgreenmachine's Avatar
Go to www.edgeracingconverters.com They have some good info on converters. Llyod Elliot recommended of three brands that an Edge converter is a good deal. He ranked them up there with Precision Industries Vigilante and Yank converters. They have a section that explains brake stall, true stall, etc, Good reading.
Old Jan 31, 2005 | 07:06 PM
click on the "basics" to get the 411
Old Feb 1, 2005 | 03:50 PM
"White Knight"'s Avatar
Mash the gas see what it revs to before you really take off flying
Or do the brake test.
Old Feb 1, 2005 | 08:46 PM
92RS305#2's Avatar
this is generally the most of the manufacturer's recommended procedures on diagnosing torque convertor stall and some general problems with the convertor.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ChrisFrez
Feb 15, 2015 07:49 AM
Collector Car
Dec 17, 2014 01:12 PM
squarehead
Nov 21, 2014 08:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
