Problem with Offset
Old Jan 26, 2005 | 03:26 AM
Blue_SS's Avatar
Problem with Offset
I'm in the process of putting on 18x9,5 Y2K C5 rims with 65mm offset in the rear. I want to use hub centric wheel adapters to make them to fit right. Is there anyway I can use a 1" wheel spacer. The reason I ask is b/c I don't want the wheels to stick out of the rear fenders. Will I get away with this ? I calculate that would put my offset to 40mm. Would I have to get my fenders walls rolled in ?
Thanks
Alex
Old Jan 26, 2005 | 09:32 AM
Chris@Tires.com's Avatar
Re: Problem with Offset
The ideal offset would be 50mm to 56mm. With that spacer putting the offset at a little under 40mm, it would be a VERY aggressive fitment. You would have to roll the fenders pretty hard.
Chris
HectorM52
Jul 30, 2017 11:46 AM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
redzed
Sep 4, 2002 06:22 PM
