window switch ??
Old Jan 23, 2005 | 05:49 PM
whatsup's Avatar
window switch ??
Mods below...running a 100 shot with MSD window switch. I shift right around 6000-6200, limiter is set for 6500 rpm. Where should my window be?
Old Jan 23, 2005 | 06:00 PM
xfreshjiv12x's Avatar
Re: window switch ??
A couple hundred rpms below where you shift
Old Jan 23, 2005 | 08:01 PM
MEAN_SBC's Avatar
I'd put it a few hundred rpm's below your rev limiter.... As long as you're not keepin it floored while you shift, you're nitrous is going to quit spraying when you shift anyways..... (If you're using a wide open throttle switch).
I run an automatic, and I've been sprayin through the shifts on a big shot for a year on my current tranny.
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
