ColdFusion direct port through injector adapter
Old Nov 18, 2004 | 02:26 AM
kevmor99's Avatar
Anyone seen these yet? (bottom of pg.)
http://www.coldfusionnitrous.net/nozzles.html
Old Nov 18, 2004 | 06:49 PM
SILVERZZ28's Avatar
Re: ColdFusion direct port through injector adapter
I likey. But does it work?
Old Nov 18, 2004 | 08:58 PM
Gimpster's Avatar
How would you use it on an LT1? Seems to me the fuel rail(s) would then be raised... guess some spacers and longer bolts?
Old Nov 20, 2004 | 06:53 PM
MadMaxz28's Avatar
yeah id like to hear from someone who uses these.
Old Nov 22, 2004 | 01:09 PM
red91z's Avatar
I have one of the NOS brand kits with the manifold and all hardware on ebay. You do have to space the fuel rails up and shorten the cross over.
Old Nov 26, 2004 | 06:07 PM
Joe Brodman's Avatar
GP Moderator
Looks similar to what NOS offers with their NOSzels kit. So the same question of how does it impact the injector spray pattern still applies.
Old Nov 26, 2004 | 09:46 PM
red91z's Avatar
The NOS version does not effect spray pattern of the injectors at all.
Jessie
Old Nov 26, 2004 | 11:22 PM
GP Moderator
Jessie
I doubt that. Just look at this picture. The injector has to sit very high up to allow for the Noszles to fit in. IMHO it's looks pretty chintzy kit to begin with, and I still can't understand the market for it. You could pay someone to tap your intake for a proper direct port setup and use a regular DP kit for the same money. Anyone that NEEDS to have a direct port setup should have already pulled their intake for other mods anyway, so pulling it shouldn't be an issue.
Old Nov 27, 2004 | 10:14 AM
The guys that built my engine (and George Baxter's) at Second Street Speed use the NOSzle system in their 7-second Pro 5.0 Mustang. They did extensive dyno testing to insure that the NOSzles did not affect the injectors in any negative way. They do use it only for nitrous injection, since they prefer dry systems.
Old Nov 27, 2004 | 10:16 PM
red91z's Avatar
I wouldn't of said it if it wasn't true. I've run the car with and without them and it makes no difference what so ever. The injector spray pattern is very tight just out of the injector.
Old Nov 28, 2004 | 01:05 PM
snorkelface's Avatar
Question Re: ColdFusion direct port through injector adapter
Although that setup would seem to narrow the spray pattern, if extensive testing has been done to prove otherwose, than I'll believe that.
However, if does basically cost the same to do a direct port system, what would be the reason to go with the NOSzle OR Cold Fusion kit?
Old Nov 28, 2004 | 05:54 PM
Lonnie Pavtis's Avatar
The reason is that a fuel injector is aimed at the valve for better fuel control. A Fogger (or other brand nozzle) needs to be positioned in the port properly to work its best. This is hard in a LT1 manifold with such a short port & the injector being stuck in the prime area. All other locations are somewhat a compromise as the spray should not be directed at the port wall, but at the valve. The NOSzle system follows the same path as the injector & the injector pattern is only affected by the extra height..... the fuel should go straight through the NOSzle without ruining the pattern.
Old Nov 28, 2004 | 06:32 PM
Thanks! Are these setups as simple as they seem as far as installation, or are there some problems with running it on an LT1?
Old Nov 28, 2004 | 08:19 PM
red91z's Avatar
They are pretty easy. When you space the rails up the crossover has to be shortened a bit. I cut mine and brazed it back together. The adapters that come in the LS1 noszle kit will work with some minor grinding. ; )
Old Dec 6, 2004 | 06:51 PM
Steve in Seattle's Avatar
So instead of tapping 8 small holes in an aluminum intake, you have to cut and braze your fule line cross-over tube?
Doesn't seem like much of an advantage. :/
hmmm....
