bullet mufflers
Old Dec 29, 2004 | 01:38 AM
Sly_Z_28's Avatar
bullet mufflers
will a bullet muffler fit on the stock i-pipe on a 94 Z?
Old Dec 29, 2004 | 04:15 PM
fragenstein's Avatar
Re: bullet mufflers
On my 93 TA... it was like $20 + bullet... to have my piped cut behind the single cat, and the bullet welded in. Also had em cut the pipe behind the rear axle, so you don't even see tips in the back.. wasn't sure how it would look... but LOVE it. Later i spent another $20-25 to have the cat cut out and straight pipe welded in... sounds awesome... but I am gonna go A LITTLE quieter eventually.
Old Dec 29, 2004 | 11:28 PM
Sly_Z_28's Avatar
Re: bullet mufflers
awsome, you have any pictures? how's the clearence, does the bullet bang againt driveshaft?
Old Dec 30, 2004 | 12:47 AM
CamaroZBoy's Avatar
Re: bullet mufflers
yes it will fit...yes it sounds good
Cory
Old Dec 30, 2004 | 09:22 AM
Shon Herron's Avatar
Re: bullet mufflers
Get the 3" bullet muflfer and have it welded in.
I hope you are running more than just the bullet...it's going to be LOUD other wise....
Old Dec 30, 2004 | 11:32 AM
teke184's Avatar
Re: bullet mufflers
you should check out my website, bottom of page 2 i think
i have a bullet muffler welded on behind the off-road pipe, a 3" Ipipe and then another bullet with a turndown tucked up under the trunk.
it sounds AWESOME and was cheap. i also painted the rear bullet and turndown with black exhaust paint so that it blends in with the underside of the car. not visible from the back.
Old Dec 30, 2004 | 11:35 AM
Re: bullet mufflers
LS1 will sound much quieter than an LT1 for sure!!
Old Dec 30, 2004 | 01:40 PM
Re: bullet mufflers
Loud... pshh. You just gotta decide how loud it should be to OTHER people... cuz if you dump way back like mine... it is quite bearable... even with only one bullet, and a straight pipe instead of a cat.
I will get pics.. if you can IM me or anything.. that would be easiest... if not i'll just post.
Old Dec 30, 2004 | 01:44 PM
Re: bullet mufflers
I have had it all....the bullets are fun at the track but get old driving it all the time...but that might have been do to the fact that I was running a 3.73/Th350 combo with the bullets....revs were over 2500 all the time.....
Old Dec 31, 2004 | 12:26 AM
Sly_Z_28's Avatar
Re: bullet mufflers
i'm going to run a catco cat or stock cat with the bullet and then cut out the stock muffler and put pipe in there to retain the dual exhaust look, it will look stock! he he. The over the axle part will be like the SLP Loudmouth or Borla were there is a y-pipe. I have heard that this setup sounds like the loudmouth WITHOUT the raspy and poping sound!
Old Dec 31, 2004 | 01:38 AM
CamaroZBoy's Avatar
Re: bullet mufflers
i have the slp loudmouth with the bullet muffler welded in place of the slp resonator, and I do not have a "poppy sound". I think it sounds really good, especially at highway speeds
Cory
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
colts0455
Sep 22, 2015 02:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
