Any advice on upper control arm bushings???
Old Dec 20, 2004 | 12:05 AM
omatter67's Avatar
Unhappy Any advice on upper control arm bushings???
Hey,
Need to put new Upper control arm bushing and outter tie rod ends to pass inspection. Told the shop I would do itmyself. Does anyone know if anything specific needs to be done in order to change them out. I heard something about the bushings being pressed in, rumor or truth? If anyone has had any experience with this certain task, feedback would be appreciated. Thanks
Old Dec 20, 2004 | 12:09 AM
Re: Any advice on upper control arm bushings???
I did the upper and lower a-arm bushings. They all came out by melting/burning them out with a propane torch. No press required. Messy, but not that hard. The ES poly replacements simply pushed in with a C-clamp.
Just a friendly hint... there is a "Suspension....." forum.
Old Dec 20, 2004 | 12:11 AM
omatter67's Avatar
Thanks man, I'll hit them up to see if anyone else has any suggestions...
Old Dec 20, 2004 | 09:22 AM
Dave Holland's Avatar
I've been looking into doing this on my v6 beater. From what I've come up with, I think there are actually two different ways of doing this depending on what kind of bushings you will be putting in. If you are going to go with OE rubber type stuff, then you will need to press the old bushings out and then the new ones in. If upgrading to the poly, then it works as Injuneer has said. What is interesting is the poly bushing upgrade is actually cheaper than putting OE style ones in. And speaking from experience having done this on other vehicles, probably easier.
Can anyone confirm the OE vs poly thing?
-Dave
Old Dec 20, 2004 | 10:11 AM
NBred94's Avatar
I did all of the bushings on my front end, and the uppers are not bad at all, provided you have a torch. If you have it all apart, you should probably go ahead and do the lowers too, but they are not as easy to deal with. I'm not sure how OE replacement bushings are made, but I think that they have come with new sleeves that would need to get pressed into the arm, after the old ones get pressed out. With Poly bushings, you reuse the old sleeves, and thus the burn 'em out method works the best.
R@mpage
Apr 20, 2015 10:02 AM
sseeya
Apr 9, 2015 06:38 AM
dbrockma
Feb 16, 2015 02:56 PM
Jason Short
Jan 19, 2015 06:34 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
