Is this a good starter mig welder?
Old Dec 3, 2004 | 07:38 PM
Mystic95Z's Avatar
Lincoln Handy-MIG
I want to get into welding and will be doing some exhaust work next spring as well as SFC's and was wondering if this was a good welder at a decent price??
-Tony
Old Dec 4, 2004 | 02:00 AM
zx1216's Avatar
Re: Is this a good starter mig welder?
dosen't look bad i guess, i got a lincoln pro core 100 last spring for 300, it is set up for flux core welding up to a 1/4 inch while that is only rated at 1/8 inch. You can convert it to mig with a $100 kit i believe which i may do, it welds exhaust fine but it is just not as clean as a mig weld would be.
Old Dec 5, 2004 | 09:04 AM
TTExpreSS's Avatar
I think its too small. it will work great for exhaust and may get the SFC's ok but you will need at least 150A to be able to do any real work. consider getting a 220V unit so you dont wind up having to do it later when you want to weld some heavy stuff.
Old Dec 6, 2004 | 12:15 PM
rpm4lalo's Avatar
I use a Lincoln Electric Pro Mig 175. It has the 220v and I use Co2 to create the pocket. It also will do gasless with the larger tip, fluxcore (.9mm) and polarity cables reversed, but the Co2 makes the welds much cleaner.
To answer your ? though, it would make a good starter kit just to practice the principles, but you will need "more" later.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Jason Short
Jan 19, 2015 06:34 PM
Jeff1904
Jan 3, 2015 12:00 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
