will ring and pinion fit
Old Nov 26, 2004 | 05:41 PM
llwta's Avatar
I have an opportunity to get a set of 3.42 gears (7.5" ring and pinion ) for my '95 T/A w/2.73 gears (2 series case). This set is out of a GMC Sanoma (S-10). Is it a direct bolt in? Thanks for your help! Larry
Old Nov 26, 2004 | 09:38 PM
Capn Pete's Avatar
Re: will ring and pinion fit
I doubt it. Factory 3.42's for the F-body 10-bolt are on a 3-series carrier. Maybe you could swap the whole carrier though? (if the Sonoma's is a posi, and if you can get it?).
Old Nov 26, 2004 | 09:52 PM
a walker's Avatar
No, it the ring and pinion will not fit. Like said, if you can get the whole carrier from the Sonoma, that will work, but it most likely will have an open carrier (no posi). The gear set will work if you get a ring gear spacer though.
oldschool
Feb 9, 2016 09:21 PM
TitoPR221
Jan 29, 2015 08:00 PM
derty
Aug 31, 2002 12:28 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
