Headers, Exhaust, Nitrous, Sub Frame Connectors
Old Nov 26, 2004 | 02:32 PM
camarokidirocz's Avatar
Exclamation Headers, Exhaust, Nitrous, Sub Frame Connectors
ok im lokin to buy some performance upgrades for my 89 iroc 305 i dont no if i should start under the hood or stiffin up the frames and if i got headers and an intake would they ft onto the LT1 in the near future when i do swap it out
Old Nov 26, 2004 | 02:39 PM
95redvert's Avatar
Re: Headers, Exhaust, Nitrous, Sub Frame Connectors
Stiffen the car with sub-frames, stb, and suspension mods first. Don't do an inatke swap if you are planning on doing a LT1 conversion. The LT1 is a one peice intake, so none of the TPI intake peices will fit it. The headers should not be a problem.
Old Nov 26, 2004 | 08:30 PM
camaroz28racer2's Avatar
Go for the SLP 1 3/4" headers if you are going to install an LT1 later, definetly if you are going to use nitrous.
Get a typical wet single nozzle nitrous system, that will transfer over without a problem.
I'd start with a set of alston subframes.
Richardan15
May 30, 2015 08:36 AM
Caps94ZODG
Sep 7, 2002 10:09 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Caps94ZODG
Jul 24, 2002 07:22 PM
Caps94ZODG
14
Jul 17, 2002 10:15 AM
