How much engine oil?
Old Oct 5, 2002 | 02:27 PM
darth_bommel's Avatar
Posting to this forum is fun Finally some people I can annoy with hundreds of questions
And here's another one
How much engine oils (in liter maybe?) do those IROCs have?
Does it make sense to add an oil cooler?
That's it, I'm done
DB
Old Oct 5, 2002 | 03:01 PM
aklim's Avatar
5 quarts or 5.6826375 Litres
They should have an oil cooler already. The oil filter hooks up to a thing that is bolted by a banjo bolt to an oil cooler with coolant running thru it. If you add an oil cooler, it may take even more oil. If you are constantly running hot, maybe use an oil cooler. Usually not necessary. External, that is.
Old Oct 6, 2002 | 04:22 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Not all thirdgens have oil coolers. I have only seen them on the TPI cars, and then only on the higher end ones, the 350's and 305's with 5-speeds.
Old Oct 6, 2002 | 07:27 PM
Lars's Avatar
I thought it was 4 quarts? That is what my Haynes manual told me.
transam_388
Mar 15, 2015 11:53 AM
Scottylt1
Jan 8, 2015 02:48 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Scottylt1
Dec 4, 2014 12:31 PM
