What offset to get for 15in draglites??????
Old Nov 22, 2004 | 09:25 PM
KamaroL98's Avatar
I am about ot order some 15X10 or 15X8 draglites, i borrowed a set of 15X10s from a friend (pics in sig) and had to SHAVE the crap out of my calipers to get them to fit. And i got comments from a few people that the offset wasent correct. Now that im about ot order my own i want to know what offset to get.
Also my secondary question, should i go with 15X10s or 8s? I know the 15X10s bogged a little when burning out, but they hooked real well.
Old Nov 23, 2004 | 12:36 PM
Re: What offset to get for 15in draglites??????
Changing the offset won't alter the interference.... at least not if your 98 brakes hit in the same place as my 93-97 brakes. The corner of the caliper fins hit the wheel "disc", and the radius where it rolls over to form the "rim". Doesn't hit the rim, so the only way to avoid the interference is to cut back the fins or move the disc away from the caliper with a spacer (not recommended on a drag wheel).
Wheel width should be based on the selected tire size, reflecting the manufacturer's recommendation. Its the tire tread widht and compound that will determine how it hooks, more than the wheel width.... unless of course you have a major mismatch between the tire and the rim.
Old Nov 23, 2004 | 05:24 PM
KamaroL98's Avatar
Old Nov 24, 2004 | 05:24 PM
Originally Posted by KamaroL98
You suggested that the 15x10 wheels caused your car to "bog" during the burnout. My point was simply that it isn't the wheel width that causes a "bog".... its how much tire you have on the wheel. What size tire was on the 15x10 that caused the bog?
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
r_hodge
Oct 27, 2002 10:06 PM
jkbadz28
Oct 2, 2002 08:58 PM
