Rmoving the LCA's?
Old Oct 31, 2004 | 11:43 AM
Myxtreme1's Avatar
Rmoving the LCA's?
I will be pulling mine off this week and was wondering if anyone had any heads-ups for me. I believe the bolt is an 18mm or so but I can't seem to get a good setting on the head. Everything is perfectly placed in the way. Any suggestions will be much apprecited. Thanks!
Old Oct 31, 2004 | 09:49 PM
Red96Lt1's Avatar
Re: Rmoving the LCA's?
It's pretty easy, and yes I think it's 18 mm. I used a 1/2" drive socket and an 18" wrench. Not a bad job, kinda cramped for space with the tools though.
Old Oct 31, 2004 | 09:54 PM
madwolf's Avatar
I used a 3/4 socket on the nut and an universal wrench to keep the bolt from moving. I think the 3/4 was a little big (although it worked fine) so 18mm should work.
The LCAs shouldn't be bad at all. The problem is that the bolt/nut may be rusted and it will be hard to take it out so you might want to spray some wd40 on it the night before.
Old Nov 1, 2004 | 12:21 AM
Z-RATED94's Avatar
What madwolf said. Spray some WD40 on the bolts at least a day in advance. It works.
Old Nov 1, 2004 | 12:34 AM
Cmr0z28's Avatar
I recommend using PB Blaster. Even then I had to stand on the breaker bar to get the damn things loose. Remember, one side at a time. If the new ones don't fit, jack up/lower the rear until it lines back up.
Old Nov 1, 2004 | 12:39 AM
madwolf's Avatar
Oh yes, forgot to mention... the shop manual specifies to tighten the LCA bolts only with the rear in curb position.
96SilverRam
Nov 20, 2016 11:19 AM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Boss002
Jul 24, 2015 10:47 AM
