Compression ?
Old Oct 31, 2004 | 06:51 AM
RealQuick's Avatar
Compression ?
I had a quick compression question.
I have the -31cc SRP pistons. What cc combustion chamber do i need on my AFR210's to end up with ~8.5 compression. I know gasket thickness, etc. plays a role, but lets just say on a standard LT1 bottom end for example. I used the calculator on this site and it said ~60cc? It doesnt sound right...
Old Oct 31, 2004 | 08:05 AM
chevyguy3's Avatar
Re: Compression ?
are you really just using stock bore sized pistons with stock stroke? if you are boring or stroking any it will affect what size head chamber youll need so we need to know that
Old Oct 31, 2004 | 08:22 AM
RealQuick's Avatar
Re: Compression ?
I am running a Cola cranl 3.75", 5.7 h beam rods and 4.030" pistons for my 383. Thanks.
Old Oct 31, 2004 | 09:12 AM
chevyguy3's Avatar
Re: Compression ?
with that bore, stroke, and a -31cc piston, assuming a felpro 1074 gasket (4.125 bore, .039" thickness) and .000 deck height, you will need a 65cc chamber to put you at 8.5:1. with -.005 deck you will need a 64cc chamber, with -.010 deck height you will need a 63cc head chamber. for best quench go with zero deck height, if you want to be able to use that block for another rebuild, leave a little deck height on it
Old Oct 31, 2004 | 10:09 AM
RealQuick's Avatar
Re: Compression ?
Thanks for the help! Thats what I was looking for.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
