Tight Fit?
Old Oct 28, 2004 | 12:27 PM
SantaCruz163's Avatar
Tight Fit?
I have a real quick question. I recentely reaplaced my old clutch with a Ram clutch and I had a question. I also replaced the old pilot bushing with a new brass bushing, not bearing, from Autozone. Now the question I have, is the input shaft suppose to fit tighly in the bushing? When I reinstalled the tranny I had a hello hard time getting the tranny to fit right up against the bellhousing. What I did was start 1 bolt on each side and 'pull' the tranny and bellhousing together. Does this sound right? I haven't had any problems :knock on wood:.
Old Oct 29, 2004 | 10:13 AM
IllusionalTA's Avatar
Re: Tight Fit?
yea they can be a lil tight.. did you put a lil grease on the tip? sometime's the disc is not perfectly aligned and would require it be pulled in.. its normal..
Old Oct 29, 2004 | 11:15 AM
Re: Tight Fit?
Yes, I put grease on the tip of the input shaft, and a little in the pilot bushing.
Victor Lamb
Aug 26, 2017 02:52 PM
96SilverRam
Nov 20, 2016 11:19 AM
sseeya
Apr 9, 2015 06:38 AM
Apr 3, 2015 10:54 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
