Throttle sticking?
Old Oct 17, 2004 | 07:05 PM
ChrisS95TA's Avatar
Throttle sticking?
Well, I have noticed that sometimes when I hit the gas the revving is delayed. I manually moved the throttle right by the spring and it was pretty hard to move, once I got it moved it had play in it buy maybe my throttle body blade could be sticking? Or could it be the spring? Not sure, would it be easy to check the TB blade and/or clean it? Thanks for any help
Old Oct 17, 2004 | 08:03 PM
)2overt SS's Avatar
Re: Throttle sticking?
I have that exactl problem with my Toyota RAV4... it's just the blade sticking I think. I took off the intake elbow and just cleaned up all the crap and other various parts where it could be sticking. Hasn't stuck since
Old Oct 17, 2004 | 08:04 PM
Dave89IROC's Avatar
clean your throttle body, remove it, clean with carb clean and an old toothbrush
Old Oct 17, 2004 | 09:03 PM
cooley346's Avatar
I did that but now my toothbrush tastes like gas. What gives.
Old Oct 17, 2004 | 09:28 PM
Dave89IROC's Avatar
Old Oct 18, 2004 | 06:17 AM
ChrisS95TA's Avatar
Cool, guess it IS that simple. But does it HAVE to come off in order to clean it? Or would I be risking having stuff get into the intake?
Old Oct 18, 2004 | 09:19 AM
Red96Lt1's Avatar
You will probably be ok with out taking off your TB. Look at it, it's probably just a little carbon around the blades and bore.
Old Oct 18, 2004 | 09:05 PM
ChrisS95TA's Avatar
Yup, I can see buildup there and also around my MAF?!?!
My air filters are on tight and my SLP CAI is still clean inside save for slight discoloring/rusting where the AIR tube hole is on the inside (still coated black on outside). Guess I gotta get some carb cleaner this week and tooth brush it. The way I figure it is if I dont use too much and use a tootbrush I can easily get everything out with the TB open and a paper towel or something that will leave nothing behind.
Thanks for the help guys Doesnt cause me too many problems but it noticably sticks sometimes, maybe when it heats up and expands probably.
Slayer
Aug 17, 2015 03:55 PM
350350
14
Aug 11, 2015 12:03 PM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
dolfan324
Jul 17, 2015 10:34 PM
