how close to coil bind is safe?
Old Sep 27, 2004 | 09:47 AM
teke184's Avatar
how close can your lift numbers be to the size spring before you should worry about being "unsafe"?
basically if you are running springs that handle .600" lift, is it safe to run .595" of lift?
or is it a better rule of thumb to give more "buffer" than that?
Old Oct 1, 2004 | 11:50 AM
teke184's Avatar
Re: how close to coil bind is safe?
anybody???
i want to know if i should "spring" (no pun intended) for .650" max lift springs or just the .600"
Old Oct 1, 2004 | 04:57 PM
Dave89IROC's Avatar
I think you want 0.030 clearance
Old Oct 1, 2004 | 10:19 PM
01SSRMS's Avatar
I was thinking .050 - .060 was the minimum. I'll take a look in a spec book where I saw it and try and give you a more definite answer.
Old Oct 2, 2004 | 11:05 AM
RE AND CHERYL's Avatar
I beleive the springs included with the Hot Cam are good for .525, which is exactly wht the cam with 1.6 RR makes for lift.
Old Oct 2, 2004 | 01:39 PM
teke184's Avatar
stock lt1 springs are rated for .525"...and i think ls1 are the same
so the springs on the hotcam would need to be more. probably .550" or .570"
Old Oct 2, 2004 | 10:02 PM
Mtrhds94Z's Avatar
I thought it was .490 for stock LT1 and .525 for LT4 springs?
Dec 1, 2016 05:37 PM
May 8, 2015 11:30 AM
kandied91z
Aug 6, 2002 02:01 PM
kandied91z
Aug 6, 2002 01:18 AM
