New w/some dumb questions
Old Sep 27, 2004 | 09:10 AM
Speedocrash's Avatar
I'm new here but not to cars. I started this perverse hobby w/ a 72 Nova moved on to a 68 Camaro but both were WAY TOO rotted to do anything with.
I've just inhereted a 84 Z28 with power nothing.
It has a bad starter. I have a few SBC starters lying around. All have a staggered bolt pattern. The car is a 5 speed but the starters are for an auto trans. Now to make this car really free i have to put a free starter in it. Can i just swap the nose over or are the internals different?
Just to let you all know it has a 305 with a 383 in the works. Has anyone else ever considered building an engine in an apartment living room and swapping it in the lot of said apartment?
Thanks in adavnce and since i've never built a stroker i'll be asking a bunch of dumb questions about that too. If any of you have any usefull links i'm always lookin for new stuff to add to my favorites.
-Steve
Old Sep 27, 2004 | 01:10 PM
Z28SORR's Avatar
Re: New w/some dumb questions
To start. there are not special or different starter for auto and stick. There are just different starter for different combinations. Mostly different flywheel/flexplate diameters.
In most cases you should be able to change the nose piece to get the right bolt patern.
Old Sep 27, 2004 | 03:35 PM
aklim's Avatar
I am using a GMPP high torque starter because I have higher compression and it works fine. No heat soak yet and I run headers. Also with the starter, it is dumb and could care less if it was behind a stick or an auto. Also, the starter gear is good for both flexplate patterns.
Old Sep 27, 2004 | 07:06 PM
Sitting Bull's Avatar
There are no dumb questions, Speedo. That's why this forum exists, so don't feel sheepish--folks here really do like to help others out
Also, try www.thirdgen.org which is the very best site on the web for 3rd gens.
Old Sep 27, 2004 | 08:26 PM
PyRo9862's Avatar
Conradulations you just made me realize what an idiot I am. The starter in my car was going so I bought a new one. I just remembered that there was a new one sitting in the garage that I got for free when I bought the parts for an auto-manual swap. Damnit.
Old Sep 28, 2004 | 08:32 PM
I got the 400 engine today in the pouring *** rain. I'm disassembling it tommorrow. It's a 4 bolt block. What are the chances of having a forged crank? Does anyone have a list of casting numbers to look for/avoid?
Thanks again
Old Sep 29, 2004 | 12:33 PM
Z28SORR's Avatar
Stock 400's were cast.
ModdedNerd
Dec 25, 2014 05:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
donot_4get
Sep 14, 2002 08:03 AM
chr10spoke
Aug 19, 2002 08:13 PM
