"Safe" to drive 200MI w/stock injectors & 8#Procharger?
Old Sep 19, 2004 | 10:06 AM
Yby4n95Z's Avatar
I have to drive almost 200 miles to where my car is getting tuned for my ATI procharger. Is this safe running it that distance with stock injectors, and no tune? If I baby it and stay out of boost I feel I will be ok. When I took my stock plugs out that were looking as if the car was running a little rich. I installed TR6's gapped @ .35 and I don't want to foul them out half way there. I am running the stock FMU and stock injectors there, then doing away with the FMU and running 38#'s.
Just don't want any problems on my trip there.
Thanks guys
Adam
Old Sep 19, 2004 | 10:20 AM
MEAN LT1's Avatar
Re: "Safe" to drive 200MI w/stock injectors & 8#Procharger?
You'll be ok, just stay out of boost and you'll be fine. Good luck
Old Sep 19, 2004 | 11:03 AM
engineermike's Avatar
Agreed. You'll be fine. If you stay at less than 2/3 throttle, the programming doesn't even affect A/F ratio.
Mike
Old Sep 19, 2004 | 12:09 PM
chevyguy3's Avatar
ditto. just be patient and keep your foot out of the gas until you have the bigger injectors/tune and youll be 100% fine
also if its not too late, i would suggest running a larger injector since you wont be using the FMU
Old Sep 19, 2004 | 05:50 PM
Yby4n95Z's Avatar
Thanks for the advice guys! I have my larger injectors allready. They are 38lb and will be installed with the tune.
I let you guys know some dyno numbers later.
Adam
Old Sep 19, 2004 | 11:24 PM
chevyguy3's Avatar
i meant i would go larger than 38lb
Klypto
Mar 23, 2016 09:05 AM
Mar 15, 2015 07:01 PM
Alex Barnes
Jan 24, 2015 10:21 PM
nophix
Nov 30, 2014 10:26 PM
