Another window switch question
Old Sep 30, 2002 | 06:30 PM
ChrisJ325's Avatar
Hey,
Ive been having a great time using my nitrous over the past month or maybe two, but today I was racing a T/A and I realized that my nitrous was spraying below the 3000 rpm starting point. I just installed a 6AL this weekend, and I followed the wiring diagrams that I got from my last thread exactly. My question is, if the window switch isnt getting a tach signal will it let the nitrous spray at any time? Im curious if my connection on the tach signal from the 6AL is good. So anyone know if the window switch will allow the nitrous to activate if it isnt receiving a tach signal? thanks for any help guys.
Old Oct 2, 2002 | 06:11 PM
ChrisJ325's Avatar
so no one knows?
Old Oct 6, 2002 | 03:11 PM
ChrisJ325's Avatar
Update: Ok this weekend Ive been checking wiring, etc, and all of my wiring work is good. I moved the tach signal wire for the window switch from the 6AL output back to directly on the coil where I had it.. Window still opens before the 3000 rpm opening point. Anyone know anything else I may want to try? Would the 6AL cause it not to read the correct rpm?? Im at a loss about what to do with this, anyone have any tips/suggestions about what to check?
Old Oct 6, 2002 | 10:29 PM
ChrisJ325's Avatar
Update2: Unhooked the 6AL, still didnt fix my problem. Any suggestions? Please? Has no one else had their window switch quit working?
Old Oct 6, 2002 | 10:57 PM
LPEdave's Avatar
Are you running the power to the window switch through a relay? It needs one, and the only time I've seen one "die" is when the power was 12V directly in to it. Have you checked with MSD or whoever makes the window switch as to what it does when it doesn't get a tach signal?
Just some thoughts...
Dave
Old Oct 7, 2002 | 02:42 PM
ChrisJ325's Avatar
Dave
I was running it through the relay with my TNT kit. Im sure its getting a tach signal now, I went back and wired it directly into the negative coil wire (how it was before the 6AL install, and how it was when it worked) and it still doesnt do like it should. Its an MSD. Thanks for the info. I followed the wiring diagram that someone emailed me from here, I think it may have been one that you drew up, even though I didnt get it from you. I guess I can go and re-wire everything again, even though I didnt see a problem with my wiring. Thanks again
Old Oct 7, 2002 | 09:33 PM
InsuranceGuy's Avatar
(1) This might sound stupid, but, what MSD rpm chip are you using?
(2) Make sure you are using the MSD window switch
to GROUND your nitrous relay.
(3)Check your relay...could be defective.
(4)Double check all wiring.
Emil Dusek:93Z,IRS383,Vortech,NX,dual MSD Window Switches
Old Oct 7, 2002 | 11:30 PM
ChrisJ325's Avatar
The switch used to work, I didnt change anything other than adding a 6AL.. I have since taken the 6AL out to see if that was my problem it wasnt. Im using the 3000 on 5800 off chips. Relay works fine because the nitrous will spray, its just like the window switch isnt there, thats why I think I killed the switch. Im going to check my wiring at some point tomorrow. Thanks
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
