Coolant Sensor is too Low?
Old Aug 3, 2004 | 04:13 PM
TArider21's Avatar
Thumbs down Coolant Sensor is too Low?
The service Engine Light came on in my car the other day, it is a 1992 camaro with a 3.1L V6, I scanned it and it said the coolant sensor is too low. Before this happened the car would not idle at any less than 1500rpm. I tried cleaning out the IAC motor, and now the engine will idle at 1000 rpm, but the check engine light is still on. Has anybody experienced a similar problem, and if so what was it?
Old Aug 3, 2004 | 04:35 PM
camaros_4_lfe's Avatar
Re: Coolant Sensor is too Low?
check your coolent???!
and if its full its porb the sensor
Old Aug 3, 2004 | 04:39 PM
TArider21's Avatar
Talking Re: Coolant Sensor is too Low?
I checked the coolant, and it is full, so it must be the sensor! Any more suggestions?
Old Aug 11, 2004 | 01:23 PM
HBHRacing's Avatar
check the harrnes. could be coroded or lose. check for a 5 volt reffeence on one wire and a full ground on the other. if thats ok change the sensor
Old Aug 11, 2004 | 06:51 PM
TArider21's Avatar
The coolant temperature sensor went bad, I replaced it, and it runs like a charm again!
blac94Z
Feb 15, 2021 09:43 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
