Callies 383 or Lunati 383
Old Aug 3, 2004 | 02:55 PM
NiteRyda's Avatar
I was looking at some stroker kits and came across two of them and was wondering which would be a better option.
1. Lunati
4340 Crank one piece rear main seal
Promod connecting rods
4032 Forged pistons (-20cc dished)
Racer plasama rings
Alecular main and rod bearings
It's Internally Balanced!!!!!!
2. Callies Dragonslayer (Low compression)
3.75" Calies forged crank
5.70" Calies Pro I- Beam Rods
SRP -31cc dished
Federal Mogul Main Bearings
Does not metion about being balanced?????
Which setup will be better for a 15psi dsc and need a head for about 9to1 compression?
Old Aug 3, 2004 | 09:22 PM
rskrause's Avatar
Re: Callies 383 or Lunati 383
Both would work fine. I really like Callies cranks, but OTOH the Pro-Mod is a really nice mid priced rod. If the price is the same and #2 is not balanced, I'd vote for #1 since balancing is expensive. Though the -20cc pistons may not give you low enough compression to run 15psi on pump gas. That will also depend on the cam.
Rich Krause
Old Aug 3, 2004 | 09:26 PM
LameRandomName's Avatar
Is either one of those a non-twist forging?
Old Aug 4, 2004 | 10:03 AM
NiteRyda's Avatar
Will 12psi be better for pump gas with this combo? And what chamber heads will get me down to 9to1 compression ratio. I will be using a 224/236 comp high lift version cam.
Old Aug 4, 2004 | 05:31 PM
rskrause's Avatar
First, you will make more power with more boost/less compression than with more compression/less boost. Intake air temps have a lot to do with how much boost you will be able to use without detonation. There are some other more subtle things involved as well.
The largest chambers for an LT1 heads are the AFR's, which are 74cc (or maybe it's 76cc, I forget) unmilled. With a ~0.040" quench height this wiull give ~8:1 static CR using the -31cc piston. This is a good combo for pump gas.
Rich
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
