Front Shock alignment?
Old Jul 26, 2004 | 06:36 PM
$hawn's Avatar
I'm changing my front shocks, and I thought I heared or read somewhere that you need to remember how something lines up or the alignment will be off. I though that the alignment changing was all in the control arms and no alignment will be needed as long as your not changing the springs? Thanks for any input.
Old Jul 26, 2004 | 09:32 PM
Re: Front Shock alignment?
You have to mark the spring shock assembly before you take it apart, so the top and bottom mounts align properly to the holes in the shock tower and the lower A-arm when you reassemble them.... its the alignment of the holes that is an issue.... not the steering alignment.
Old Jul 26, 2004 | 11:35 PM
$hawn's Avatar
Oh, ok I gotcha, I thought I read something about the steering alignment being an issue. Thank you.
Old Jul 27, 2004 | 09:44 AM
Hyperspeed97z28's Avatar
So one does NOT need an alignment after a shock install ???
96SilverRam
Nov 20, 2016 11:19 AM
Fastbird93
Jun 3, 2015 05:56 AM
Boss002
May 20, 2015 12:55 PM
BLK1997Z28
May 1, 2015 12:23 PM
Hurin
Dec 13, 2014 07:38 PM
