P0133, P0141, P0147, P0300
Old Jul 26, 2004 | 02:09 PM
invictusfortis's Avatar
(wasn't getting responses in the computer forum, so I posted here)
My car had been running pretty crappy, hesitation in higher RPMs, so I took it to discount and had em run a code scanner on my PCM, getting these codes:
P0133
P0141
P0147
Which are all oxygen sensor issues; I've pretty much determined what the P0133 and P0141 codes mean, and which sensors they reference, but I can't find P0147 in my Haynes manual. It is a 96 3.8L. I also I was told that there were 4 sensors, 2 upstream and 2 heated downstream, but the Haynes manual only talks about 3 - can anyone clear this up?
Edit:
Also getting P0300 which is engine misfire, could this be being caused by the bad sensors or is it unrelated? Spark plugs are pretty much brand new. Could it be timing? Car does have close to 100k.
Old Jul 27, 2004 | 12:34 AM
99blackSS's Avatar
Re: P0133, P0141, P0147, P0300
P0147- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3).
3 sensors, 2 upstream and 1 downstream.
Did you get new plugs AND wires?
Old Jul 27, 2004 | 05:52 PM
HBHRacing's Avatar
P0133 Heated Oxygen Sensor (HO2S) slow response Bank 1 Sensor 1
I would be starting there. Thats gonna be a problem is that sensor is bad. sounds like it's faulty or contamintated. Wen it responds slowly it will not give correct feed back to the computer.
Old Jul 28, 2004 | 12:55 AM
Wires seemed alright, so I just replaced the plugs. Think I should get new wires? So is the timing theory not a possibility?
Old Jul 28, 2004 | 01:42 AM
99blackSS's Avatar
I just realized it's not a specific cylinder misfiring, so it's probably not your wires/ignition related. If someone asked me to take a guess at the cause...
I'd say F*** YOU...
then if I was asked again I'd guess vacuum leak.
Old Jul 28, 2004 | 02:09 PM
96Banshee's Avatar
does ur SES lite flash any????.....i had an engine mifire also and went thru hell fixing it ( new wires/plugs/coil packs ).....so if your driving and ur SES lite is flashing at ya then youll know its a bonafide misfire
Old Jul 28, 2004 | 03:14 PM
Yeah, my check engine light is on. I just assumed that was because of the O2 sensors malfunctioning.
Old Jul 28, 2004 | 08:03 PM
Pabz2k1's Avatar
I'm having the same type of problem with my 2k1 V6. Let me know if you have solved the O2 Sensor problem and how you did it. The only thing's I've done is replace the 2 Sensors in the front and put a Caspers Simulator in the back and that hasn't worked. I want to get rid of my SES light as soon as possible.
Old Jul 28, 2004 | 08:14 PM
99blackSS's Avatar
Did you reset you SES light after putting in the new 02 sensors?
Old Jul 28, 2004 | 09:01 PM
Pabz2k1's Avatar
Yeah I did the disconnect the battery trick. But the light came back on faster than it did before.
Old Jul 29, 2004 | 02:20 AM
well i guess im going to get off my *** tomorrow and start trying to narrow it down, see what the spark plugs look like...if they're all messed up, then its distributor/fuel prob...if only one or a few then its the plug or the wires...and i bought this thing to test the timing, so ill do that too...how do i test for a vacuum leak? anyway, couple of other guys i know said the misfire, thats being caused by whatever else, could be whats making the o2 sensors bug out...pabz, is your engine missing as well or is it just the o2 sensors thing?
Old Jul 29, 2004 | 09:00 AM
Pabz2k1's Avatar
Just the 02 Sensor thing.
Old Jul 30, 2004 | 07:20 PM
dunno then :\
Old Aug 3, 2004 | 12:45 PM
ImportKILLER's Avatar
**EDIT**
Eep...I'm not firing on all cylinders today.
Nevermind.
SPEEDYGUN
Jan 14, 2006 07:16 PM
anasazi
Oct 26, 2005 01:02 PM
kingman109
Dec 20, 2004 02:22 PM
invictusfortis
Jul 25, 2004 05:38 PM
