Wheel hop?
Old Jul 26, 2004 | 02:03 PM
chevy1963's Avatar
Wheel hop?
What cuases wheel hop? Too much traction? or not enough?
This past weekend is the first time I had the problem, with hop at the track I have mine dropped 1.8 inches with bmr relocation brackets but I didn't have them on the last hole.
Old Jul 26, 2004 | 03:02 PM
greezemonkey's Avatar
Re: Wheel hop?
I don`t think it`s a matter of too little or too much traction, Basically your suspension is unable to control the axle...Wheel hop happens when your suspesion loads and unloads...bushings, shocks, tire pressure are the usual problems, I`m sure others will chime in too but spring wrap up, poor pinion angle can also cause it
Old Jul 26, 2004 | 04:29 PM
Re: Wheel hop?
The only thing pushing your car forward on launch is the LCA's pushing on the chassis. If the LCA's are angled down from the axle to the body, as the LCA pushes down on the body, the reaction at the axle end of the LCA tends to lift the axle... unloads the tires, tires spin, loss of forces in the LCA, lift on the axle disappears, and the tires regain traction and the process starts all over again... hop, hop, hop.
With a car that has been lowered 1.8", you should have the LCA's in the lowest hole on the relo brackets, and even that may not be enough. You may want to use an airbag in the passenger side rear spring to keep the body from squatting on that side, and contributinig to the problem.
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
