Finaly
Old Jul 25, 2004 | 04:57 PM
Lisa33's Avatar
Finaly
Friday, Went to a dyno to get it tuned first pull was 510rwhp (mail tune) after 2,5 hours it was 571 rwhp (5900rpm)
Saturday, Tried to fix my shiftpoints,(High stall) didnt get it perfect 1->2 around 5500 2->3 =never, bounce the rev limit everytime, so the solution was to let of the pedal for a short time to let it gear Also noticed that i have sparkretard and no knock count al the time (no problem at the dyno)
Sunday went to the track...did 6 run and the first/worst was 11.2....
11.05 11.06 11.08 124.5-125.5mph 60fot was 1.62-1.67 1/8 7.1 101mph thats whidh 3-5 degres sparkretard and letting of the gas for the 2->3 gear...
http://www.mek.nu/racing/040725_lazz...s/image223.htm
Dont know what to do about the tranny, proberbly going for a 4l80E this winter...
So next thing will be to find out why i got sparkretard and no knockcounts ANY ideas? after that 10.xx ???
Engine: 383LT1 9.0comp ported stock heads cc305 p1sc 12psi twin IC hooker shorties
transmision: rebuilt 4l60e (2 times this season), Vigilante 9.5" converter (around 4000-4500 stall) strange 12bolt 3.42
Full weight (or more) 1995 Z28
Homemade Subframeconnectors , LCA, Modified stock torque arm, BMR lower control arms, 1,5" lowering springs...
Old Jul 25, 2004 | 08:51 PM
MEAN LT1's Avatar
Re: Finaly
Automatics are the devil.....I went through the same ordeal with my 4l60e except it wouldnt shift to 2nd(obd1 high stall problem). So after two "built" tranny I finally gave up on it and am going 6-speed. What you could is up the rev-limitor to like 6500 and and if your shift point are below that it should shift before it get to 6500. I know mine never shifted when I wanted it too.
Old Jul 25, 2004 | 09:49 PM
engineermike's Avatar
Re: Finaly
TH-350 here after breaking 2 4L60E's.
Consistently, though, my car compared to others dyno's less for the same mod's, but yet runs good numbers.
With the mod's in the sig, I dyno'd 550 rwhp and have run 10.40 at 133 mph in my 3700 lb pig.
Mike
Old Jul 26, 2004 | 02:24 AM
Lisa33's Avatar
Re: Finaly
Mean LT1, My rev limiter is set to 6300 and the 2->3 shift begins around 5600 rpm and hit the revv limiter direct, I dont know if its a good idea to raise the rev limit to 6500 beacuse then the P1SC should hit 61777rpm...
Mike, Nice times About HP, i think it was more like 510-520 rwhp at the strip, it was around 4-5 degrees sparkretard from the start, But i dont think i will reach youre times maybe 10,7-10,8 (ok tranny and no sparkretard).. Have consider going th350 or th400 but i dont like the idea of losing my 4th gear and lockup, We do a lot of highwaydriving with the car and normal cruisingspeed here is 75mph....
Should ask my tranny shop if its someting more to do about the 2->3 shift, if not
Old Jul 26, 2004 | 12:24 PM
Acct 23749's Avatar
Re: Finaly
Are you running the "12psi" pully or are your really running 12psi boost?
What size blower pully?
Old Jul 26, 2004 | 01:58 PM
Lisa33's Avatar
Re: Finaly
7.65" and 3.3" (custom made) 8rib no slip = 11-12psi around 5900-6100 on my engine....
Also have a 58mmtb, Big F1 air filter, Homade intake elbow http://home.koping.net/u3243a/images...s/DSC01582.JPG much bigger ID than the one ATI sendt (had smaller area than my 58mmtb) a friend of mine modified the twin Ic for better flow/cooling (center the inlet on them).
Old Jul 27, 2004 | 09:10 AM
1st and goal's Avatar
Re: Finaly
Hi,
Nice numbers
If you're having trouble with controling the tranny and shift points you might want to consider a T-Com ( www.fuelairspark.com ). I am running one and it shifts when I want it to (also running a 4L60E).
What kind of timing are you running?
My motor sounds similar to yours except for a tad more boost , also not sure what kind of heads you are running.
Marc
P.S. Nice homeade elbow
Old Aug 3, 2004 | 12:52 PM
Lisa33's Avatar
Re: Finaly
Should check the link you posted, (have been on a holliday trip)
about my heads, They stock castings whit stock valves ported by a pro but not max ported just a cheap port jobb widh "radius" ? valve seats....
jtk
Jul 2, 2004 12:05 PM
faded93bird
Jan 12, 2004 12:10 AM
funina91ss
Sep 13, 2003 11:13 AM
blackz151
Jul 9, 2003 11:44 PM
