Will 275/40/18 fit with out rubbing?
Old Jul 14, 2004 | 11:22 AM
ROWYCO's Avatar
Will 275/40/18 fit with out rubbing on my 95 TA?
Old Jul 14, 2004 | 03:54 PM
A 275 tire really should not cause any problems on a 4th Gen, since the SS/WS6 cars came stock with 275's. It all depends on the width and offset of your wheel, and where it sits relative to the inner fenders and the outer fender lips.
Why not get a 275/35-18 though, and more closely match the stock tire diameter, eliminating any speedo correction? A 275/40-18 is 1" larger in diameter than stock. That means it lifts your car 1/2" higher off the ground than the stock tires, and pushes the tire 1/2" further up into the wheel wells (not a problem with a stock ride height, actually looks better, but could increase the issues of rubbing on a lowered car). A 275/35-18 is the same diameter as stock.
Old Jul 15, 2004 | 07:47 AM
94BlackBowtie's Avatar
What he said! ^^^^^^^^^^
The 35's will look much better IMO.
I am running a 245/35...but I am also 1.x" lower.
Jun 6, 2015 08:27 AM
1963SS
Feb 6, 2015 10:05 AM
ModdedNerd
Dec 25, 2014 05:51 PM
roofo
Aug 26, 2002 02:00 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
