Z06's did NOT fit!!!!
Old Jul 9, 2004 | 10:30 PM
Black6SpdTA's Avatar
Angry Z06's did NOT fit!!!!
Went to have the rims put on today. Fronts went on perfectly. Rears (18x9.5 Z06) wouldn't fit. The center wouldn't clear the hub and therefore the studs didn't have enough thread to catch and the rim wouldn't have a completely flat sitting surface.
As of now, tomorrow morning I'm going to grind the hub down enough to slide the wheel over it. I'd be suprised if it's a 32nd" that needs to be ground. So close, so close.
What did all yall with Corvette wheels do?
NOTE: The front (17) and rear (18) centers are the same. I.E. The front center won't clear the rear hub either.
Old Jul 9, 2004 | 10:58 PM
97WS6SCharged's Avatar
Appearantly it's a common problem with using newer wheels on the older rearends. Just bust out the dremel and sand paper and go to town. And don't forget the digicam while you're at it.
http://web.camaross.com/forums/searc...by=&sortorder=
Old Jul 9, 2004 | 11:02 PM
Chris!!! Thanks man! Holy crap that is a relief. No pics yet, but while the car was on the lift with fronts installed and rears hanging....the car was glorious.
I'll hit you back tomorrow night with pics. Take it easy.
Old Jul 10, 2004 | 12:01 AM
Its just about 1/32"..... 0.030" to be exact. That's how much larger the rear hubs are than the front hubs, up until late 96 or early 97 models. Most people grind/sand the inside diameter of the opening in the wheel.
Old Jul 10, 2004 | 12:05 AM
Oh goody, then I shouldn't have any problems with mine if I ever buy some. Or atleast I hope I won't.
Old Jul 10, 2004 | 02:39 AM
Zack's Avatar
my afs wheels took some pounding by me to get them to seat against the hub. The use of the impact gun help to insure to sat
Old Jul 10, 2004 | 09:16 AM
UPDATE
Ground the driver's side hub, not enough obviously. I put the pass wheel/tire on (clear on drivers was drying where a little chrome started chipping). I tightened it down and now it's stuck on there. I mean STUCK!
I ***-a-long'ed my wheel/tire to the rear wheel on my little brother's Bird and it just pulled my car (on jack) so I stopped. That's how much pressure there is. What can I do? How much does cold really affect it? I was going to go lay some bags of ice on it for an hour or so--see if that helps
HELP!!!
Old Jul 10, 2004 | 01:29 PM
Problem solved! Rears are on and fronts are getting mounted in like 15 minutes. How did I get the stuck wheel off? One Word: BFH
I'll get pics up asap. Here's where they'll be:
www.cardomain.com/id/black6SpdTA
Old Jul 10, 2004 | 05:08 PM
Old Jul 10, 2004 | 05:10 PM
Why would you do that... very dangerous. The stress could fracture the wheel at the hub. The wheel may not properly "center" on the conical lugs.
Old Jul 10, 2004 | 05:23 PM
Definately a big improvement.
Now go show the Mach a thing or two.
Old Jul 10, 2004 | 05:41 PM
There he is. I knew you'd check here that's why I didn't email you. Yeah, that Mach 1 could probably toast me. I think I need plugs/wires badly. But, I'm a lazy muslim so am going to wait until I get headers to change them. Talk to you later Chris.
-Corey
Apr 3, 2015 10:54 AM
WildRidez
Feb 23, 2015 07:24 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
hotrodyou1
Dec 20, 2014 10:05 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
